Drives: 2007 Toy Corolla, 2012 Subaru BRZ
ECU reset after Break-In
Is it a good idea to reset the ECU (disconnect/reconnect battery) after break-in (at 1000 miles/1600 Kms)?
Drives: Raven Black
Ya sure why not.
Drives: 2013 Subaru SWP BRZ Limited 6AT
My 2 cents here, but I don't see why people keep wanting to reset the ECU. The ECU is supposed to keep varying different variables of the vehicle based on the parameters set at the factory. Such as fuel/air ratios and other things. I'm no expert, but reseting will only just restart the process of it doing what it does. Reseting it won't change the parameters set at the factory.
Dunno maybe an expert can chime in here...
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#4 | |
Drives: 2013 FRS - Whiteout
Resetting the ECU will have it re-learn its parameters for things like how much fuel at what RPM and load can it run without causing knock within tolerances of the stock base maps. I don't think you'll gain much benefit out of resetting your ECU after an oil change. It shouldn't cause much harm though. FWIW, I did not reset my ECU after doing an oil change.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified |
Drives: Subaru BRZ
Toyota and Subaru have said that the ECU learns during the first 100 miles and not all that much after that. They said that the reason for the rough idle and stalling that some drivers are experiencing is the result of the ECU trying to operate outside its original learning curve. Toyota is replacing ECUs and Subaru is reflashing theirs.
What I don't understand is if they tell you to keep the rpms under 4000 for the first 1000 miles how can the ECU accurately learn your driving habits? http://www.motorauthority.com/news/1...stalling-issue |
Thanks all for your comments. Let me clarify. I don't have the CEL/Idle problem. And my rationale for ECU reset (not reflash) is that my driving pattern will change after break-in. I will be routinely going past 4000 rpms. So I'm thinking a reset would help the ECU re-learn my new driving pattern and adapt engine parameters accordingly.
Drives: Subaru BRZ
If you read that article it appears that resetting the ECU will not do that much. It is why Toyota is replacing theirs and Subaru is reflashing theirs.
#8 | |
Ive had ALOT of cars in my time (showing my age!) |
#9 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The ecu probably goes into open loop at 4000 rpm. |
| TPMS reset charge | FRiSson | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 03-09-2014 02:22 PM |
| Bluetooth causing head unit to reset? | Eric1855 | Electronics | Audio | NAV | Infotainment | 4 | 01-15-2013 09:42 PM |
| Oil change after break in? | oops86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 32 | 08-03-2012 01:09 AM |
| End of break-in! Now where do we go play? MTL | QC-FRS | CANADA | 3 | 06-29-2012 11:05 PM |
| How did you break in your engine? | WolfsFang | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-05-2012 02:12 AM |
