Old 10-06-2012, 08:52 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
V8 10,000rpm into 86
Someone do this please....
Yes it's a lot of money. But, an 86 with this motor would be
http://www.radicalperformanceengines...b459662ba1.pdf
http://www.radicalperformanceengines...ds/RPV8PDF.pdf
diss7 is offline   Reply With Quote
Old 10-06-2012, 08:53 PM   #2
Yruyur
Yruyur's Avatar
Center of gravity would be above the roofline. Balance would be 95/5.
But would be entertaining to see.
Old 10-06-2012, 08:54 PM   #3
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
would be sweet, however, I'd rather see 300hp from the N/A F20 in the car already. Bump the compression up to 13:1 then get some cams/full exhaust and I bet the standard motor would surprise you.
SkitterSkotter is offline   Reply With Quote
Old 10-06-2012, 08:59 PM   #4
diss7
lolwat
It's not some POS donk V8, it weighs less than an FA20! Handling would improve!
Old 10-06-2012, 09:01 PM   #5
diss7
N/A 300rwhp from the FA20?
Old 10-06-2012, 09:02 PM   #6
dabocx
dabocx's Avatar
Drives: Scion FRS
I still think the FA20 will put down some dam good numbers will a fully built N/A motor. Maybe not as high as the honda K20/k24/f22 guys are doing but more that enough for this car.
dabocx is offline   Reply With Quote
Old 10-06-2012, 09:15 PM   #7
SkitterSkotter
Honestly it's VERY similar to the F20 in the AP1 S2000 if it were to have the same redline. I really think that n/a is the way to go with this engine. Sure the turbo works and gives lots of power...but at the end of the day I worry that 12.5:1 compression + boost will hurt the longevity of the motor.
Old 10-06-2012, 10:11 PM   #8
fatoni
its hard for me to think like that since if you can afford the cost of avoiding a turbo while making turbo power, you have already spent as much as you would need to replace your blown turbo motor.
Old 10-06-2012, 11:04 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Of course boost will bring down life expectency for the engine. Its up to you to see if you plan on driving it 150k miles or 30k miles in 10 years...if you are always beating on the car and plan to keep it for a while, dont boost it on stock internals
Silverdub is offline   Reply With Quote
Old 10-07-2012, 12:11 AM   #10
D1 86
Drives: Ae86, Jzx90, jzx110
How much do these motors cost?
D1 86 is offline   Reply With Quote
Old 10-07-2012, 12:17 AM   #11
2013GTRNate
2013GTRNate's Avatar
Bad idea IMHO… Just not what this car was designed for… Albeit you could make this car a mini Supra...
2013GTRNate is offline   Reply With Quote
Old 10-07-2012, 12:18 AM   #12
just86
just86's Avatar
Drives: 2013 genesis rspec
stop dreaming this would never happen
just86 is offline   Reply With Quote
Old 10-07-2012, 12:41 AM   #13
diss7
Would be close to $40kNZD landed.
Old 10-07-2012, 12:47 AM   #14
D1 86
Same as the synergy v8.
Still pretty cool though!
