Old 10-13-2012, 12:16 AM   #1
driver01
Drives: brz 13
Delete
Delete
driver01 is offline   Reply With Quote
Old 10-13-2012, 12:39 AM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
When I think about FR-S, I don't think about drag racing... even after forced induction. But think of any other rwd car drag setup, and it won't be much different.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-13-2012, 05:32 AM   #3
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Wider, stickier tires on wider wheels will be the best place to start. Look at tires like the Dunlop Star Spec, Yokohama AD08, Hankook RS3, and Bridgestone RE11.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-13-2012, 10:47 AM   #4
RaceR
Drives: 2010 Cooper S, 74 Beetle
Learning throttle control will be the best "mod".
Otherwise the usual stuff with stickier tires, setting up a good suspension and adjusting wheel angles for you taste. That will take time to get optimized for your personal preference...
Please don't make it into a drag focused car! There are better cars out there for that..
The more hardcore you go in terms of quarter mile modifications the less good the car will be at cornering and basically everything..
Tuning a good car are mostly compromises. You add some to one place, and you loose some at another.. (speaking about chassis modification)
RaceR is offline   Reply With Quote
Old 10-13-2012, 11:01 AM   #5
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I would get the Whiteline Traction kit for sure to start if i was making a lot of hp.
JoeBoxer is offline   Reply With Quote
Old 10-13-2012, 11:06 AM   #6
CBR600RR
Drives: Raven Black
Wider tires/wheels usually means a heavier set up which would actually rob power, not put more down.
Old 10-13-2012, 12:01 PM   #7
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Handbook rs3 for sure
RWD-boxer is offline   Reply With Quote
Old 10-13-2012, 03:57 PM   #8
Miniata
Not necessarily. There are plenty of lightweight 17x8 and 17x9 wheels available that are 4-5 lbs lighter than stock, allowing you to go with a heavier wider stickier tire and keep the wheel/tire weight very close to what the stock combo weighs. Even if you gain a couple of pounds per corner, it would be worth it IMHO if you're putting a lot more power down.
Old 10-13-2012, 04:13 PM   #9
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
A 2700lb car and rwd with an engine that loves boost. Perfect car for drag racing.
Tansey86 is offline   Reply With Quote
Old 10-13-2012, 04:13 PM   #10
Tansey86
Tansey86's Avatar
Not sure if this was serious?
Old 10-13-2012, 05:13 PM   #11
low trq
Drives: 2013 Honda Fit sport
With this flawed line of thinking, a Lotus Elise would be perfect for a drag strip.
low trq is offline   Reply With Quote
Old 10-13-2012, 05:43 PM   #12
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
I was under the impression that the high compression ratio meant that it was an engine that didn't like boast... NA4life!
jimmillion is offline   Reply With Quote
Old 10-13-2012, 06:16 PM   #13
Tansey86
Tansey86's Avatar
450 wheel and traps 130...yeah defiantly flawed.
Old 10-13-2012, 06:16 PM   #14
Tansey86
Tansey86's Avatar
520 wheel with 20psi, seems to like it to me.
ITB, how much more power? 1660 Engine, Exhaust, Transmission 119 01-22-2014 06:38 AM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-27-2013 12:49 AM
engine power bill323 Scion FR-S / Toyota 86 GT86 General Forum 25 08-06-2012 03:39 PM
BRZ STI NA with more power Harinjo BRZ First-Gen (2012+) — General Topics 79 12-22-2011 05:24 PM
is your new M3 down on power? NESW20 Other Vehicles & General Automotive Discussions 6 12-27-2009 11:03 AM
