Old 10-23-2012, 08:44 PM   #1
ninjasaurusrex
Drives: 2013 Raven Scion FR-S 6MT
DIY Antenna Stem Removal
ok so i did this firstly because i didn't like the antenna and i dont see any reason to pay for a shark fin antenna when we practically already have one on there..also this is probably the easiest diy ever..
i'm planning on using a bolt of some type and plastidipping it, but the ones i bought are a little too long
I also did not notice any loss in signal with the radio stations I listen to here in Houston, your miles may vary
1. Remove antenna
2. Place Screw in antenna hole to prevent any rusting of the inside of the antenna
3. Profit
ninjasaurusrex is offline   Reply With Quote
Old 10-23-2012, 10:43 PM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
Let me know when you find out the thread size screw fits. Gonna do this too, with plastidip.
Old 10-23-2012, 11:08 PM   #3
ninjasaurusrex
i misunderstood your statement. i'll post the screw later if i can find it
Old 10-23-2012, 11:30 PM   #4
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Looks like someone swiped your antenna. Have you considered one of the cheap 2" shorty antennas?
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 10-23-2012, 11:32 PM   #5
CBR600RR
Drives: Raven Black
Nice!
I actually pulled my antenna off about three weeks ago and tested the reception and found that i lost no service as well, but then i decided to put the antenna back on because of the hole it left behind. I think ill do this.
Old 10-24-2012, 12:55 AM   #6
Synack
Boosted
Synack's Avatar
Drives: Sideways
Well I'm not too concerned with the length of the screw. Just want to make sure I get the right size diameter/thread/etc.
Old 10-24-2012, 12:57 AM   #7
ninjasaurusrex
well here's what i bought
Old 10-24-2012, 01:21 AM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
Maybe you can just show me at a meet or something
Old 10-24-2012, 11:23 AM   #9
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
MmMmm....."Virgin materials..." lol
ProjectD is offline   Reply With Quote
Old 10-24-2012, 01:03 PM   #10
ninjasaurusrex
yeah definitely...you going to coffee & cars next week?
Old 10-24-2012, 01:08 PM   #11
Synack
Boosted
Synack's Avatar
Drives: Sideways
I REALLY hope so. Probably gonna have about 325whp if I do show up.
Old 11-01-2012, 04:41 PM   #12
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
I was always wanting to ask you..how does the turbo feel compare to the original? And also, how much psi are you running?
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 11-02-2012, 01:09 AM   #13
Synack
Boosted
Synack's Avatar
Drives: Sideways
8.5psi got us 301whp on meth.
Making a guess I'd say 11psi might net us 350whp with E-85.
This is the easiest way to describe it compared to stock. It feels a tad bit touchy when you let off the clutch driving normally. When you floor it from 2500rpm in 1st gear it feels like the stock engine with a good tune up until about 4000rpm and then all of sudden shit just starts to get crazy. And it doesn't stop there, the higher you go through the RPM's the more power it gets. At around 4500-5000rpm under full load the wastegate opens and the meth kicks in and it's pure awesome. But it doesn't stop there. You shift into 2nd gear. And if you're good enough at shifting you won't lose much boost and you'll have most of the power you had at max RPM at 5000rpm. As long as you can hold your boost well this thing flies.
I personally can't friggin help myself when it comes to power so I told them to bump me up to 350whp. This thing will have the pull of a 500whp muscle car once boost kicks in (350whp).
It would be glorious if I could twincharge this motor lol.
Old 12-08-2012, 04:12 PM   #14
DangerRuss
DangerRuss
DangerRuss's Avatar
Drives: 2013 FR-S Firestorm MT
Just thought I would share what I did with your technique. I bought the exact same set screw that you have pictured, and I also bought some #10 hinged screw covers (black plastic). The set screw is just ever so much larger than the hole in the screw cover, so I used an allen wrench and turned the screw through the hole, then attached the screw to the hole where the antenna was. Looks pretty sharp to me and gives it a nice finished look. Cant be beat for $3. Also I have lost no radio reception and still pick up all the HD channels.
DangerRuss is offline   Reply With Quote
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 02:19 AM
DIY: Antenna removal Hardrock4445 DIY (Do-It-Yourself) Guides 35 12-14-2021 11:00 PM
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 12:55 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
CAT removal in the frontpipe, CEL? Areddi Engine, Exhaust, Transmission 5 08-18-2012 05:22 PM
