Old 10-24-2012, 02:05 PM   #1
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Lowered Car, Losing traction while getting off drive ways
I just lowered my car with coilovers. minimal 35mm drop and im having a hard time getting off my driveway
I take the wide sharp angle every time, the bumper clears the drive way but once i go further something else hits the ground i dont know what it is and i loose traction.
car shakes a bit, traction control lights come on, rear wheels just spins.
has anyone experienced this?
i had lower cars in the past and i didn't have this issue.
just wondering what it could be
86_ZN6 is offline   Reply With Quote
Old 10-24-2012, 02:06 PM   #2
CaptainSlow
CaptainSlow's Avatar
Check under the car for scarring/scratching.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 10-24-2012, 02:10 PM   #3
tnt
Drives: argento frs at
hmmm, I had mine lowered on an Eibach Sportline and got no issues so far ... the ride is stiffer though.
tnt is offline   Reply With Quote
Old 10-24-2012, 02:13 PM   #4
DarkSunrise
DarkSunrise's Avatar
Sounds like you're unloading one of your rear wheels. This car has a torsen limited slip differential -- if one wheel loses traction completely (i.e., gets lifted into the air), the LSD will not be able to direct torque to the wheel with traction. Just the way torsens work.
Get a buddy to watch from the outside and see what's causing your rear tire to lift off the ground.
Old 10-24-2012, 02:14 PM   #5
CaptainSlow
Next time it happens, shift into neutral, pull the e-brake, get out, and look. You may be getting one wheel up enough to break traction with the ground (which would screw with everything).
Getting out and looking will be your best bet.
Old 10-24-2012, 02:15 PM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
it's definitely coming from the front.
it doesn't sounds like metal so that's good.
sound like plastic scratching
i will check this out once car returns from corner weight balancing and alignment
Old 10-24-2012, 02:19 PM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
makes sense
forgot to mention my right side rear is lower than the other 3 sides. can this cause the issue of it putting the load to one side and lifting the other side?
Old 10-24-2012, 02:20 PM   #8
CaptainSlow
Anything rubbing in the front shouldn't cause you to lose traction in the rear. Sounds like you may have 2 things going on.
The rubbing in the front could be from the tire rubbing against the fender liner...check that for marking/burning (or check that as well if you get out and look when you hear it).
Does it only happen if you back out? Or does it happen when you pull in as well? What about if you back in/pull out?
Old 10-24-2012, 02:20 PM   #9
#87
I usually post drunk
#87's Avatar
3 wheeling?
#87 is offline   Reply With Quote
Old 10-24-2012, 02:21 PM   #10
CaptainSlow
makes sense
It might, depending on how much suspension travel you have, how stiff the suspension is, and the angle....might tripod.
Old 10-24-2012, 02:23 PM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
ah ok thanks. yeah corner weight balancing should correct all for side then
lets see what happens
Old 10-24-2012, 02:29 PM   #12
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
only happens when im pulling out of my driveway.
no problems going back in
Old 10-24-2012, 02:32 PM   #13
CaptainSlow
Do you turn one specific direction to get out? Like, happen to always turn right? Doing that, you may be compressing the front left, pushing it up into the wheel arch (rubbing on the liner), or possibly scraping the bumper. That could lift up that rear right wheel (since it's already up higher) enough to trick the sensor/lose traction.
Old 10-24-2012, 02:38 PM   #14
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
when i exit the drive way. the street is sloping down
i only exit and angle to the left since there is always a car parked to the right. so in effect i am exiting to the left and going up the slope
i havent tried exiting to the right
Seeking lowered 86 with stock wheels DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 10-12-2014 09:12 PM
Pictures of lowered FR-S/BRZ nocurfew Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 03-26-2014 06:18 PM
Lemon laws or equivalent ways to resolve issues with Toyota in Canada? Ahz CANADA 2 09-11-2012 10:49 AM
anyone with their car lowered ~2.8in! white86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-18-2012 12:54 PM
