Old 10-28-2011, 09:36 AM   #1
Gabbo1976
Drives: Golf GT-TDI
Exclamation First Drive Review of Toyota FT-86 / Scion FR-S Mule! [Car magazine]
Hi, thought I would post a link to Car magazine article, can't see anyone else has posted it. Cheers!
Toyota FT-86 coupe (2012) CAR review
By Ben Barry
28 October 2011 10:55
On 20 May 2011, CAR was allowed behind the wheel of a Toyota FT-86 development mule to get our own driving impressions and to give feedback to Toyota’s engineers during a secretive test session in Germany. Now, as the car is about to be unveiled at the 2011 Tokyo motor show, it’s time to reveal all.
Where does the Toyota FT-86 name come from?
‘FT’ means Future Toyota, and is a label given to Toyota concept cars. The ‘86’ plays on the Toyota Corolla GT Coupe, the 1.6-litre DOHC, rear-wheel drive coupe that enthusiasts refer to by its AE86 chassis-code. The implication, then, is that the FT-86 is a 21st century AE86.
The FT-86 tag will be dropped for production. At the time of our drive, there was still a great deal of debate as to what the car would be called. The engineers were very keen on the AE86 link, while the marketeers thought that very few people would know what that symbolised – they preferred Celica. It is, however, likely that an 86 suffix will appear in some markets.
What's the specification of the new Toyota FT-86?
The key info here is that Toyota is developing the FT-86 in tandem with Subaru, who will also sell the car, in much the same way that Citroen, Toyota and Peugeot sell the C3/Aygo/107. So, this explains why the FT-86 uses a Subaru 2.0-litre flat-four engine that produces around 200bhp and 170lb ft. Unlike pretty much everyone else these days, Toyota has shunned turbocharging, but the engine does benefit from Toyota’s D4S direct injection, which helps towards a C02 figure of around 160g/km – a similarly powerful Renaultsport Clio manages 190g/km.
The engine is mounted up front, but low and relatively far back in the engine bay. It’s mated to a close-ratio Aisin gearbox (as used by Toyota elsewhere), while a Torsen rear differential sits between the driven rear wheels. The overall weight distribution is 53/47% front to rear, while the production car will weight around 1200kg.
The platform is newly developed, and I managed to put eight of my size 11 footsteps between the front and rear wheelhubs, giving a wheelbase of around 2400mm – similar dimensions to a Mini hatchback.
Elsewhere, there’s MacPherson strut front suspension, and a double wishbone rear-end. Mitsubishi supplies the springs, while test cars ran both Sachs and Showa shock absorbers – we tested the Sachs set-up.
What's the FT-86 like inside?
You sit low down – lower than a Porsche Cayman, claim the engineers – and squish into a comfortable seat with leather bolsters and grippy suede centres. The driving position is excellent. The FT-86 is strictly a 2+2: there was no room whatsoever for my legs in the back with a six-feet-tall driver in the front.
The rest of the interior was still heavily camouflaged but we did see aluminum finishes on the rotary climate control dials, plus a row of aluminium-topped switches. Toyota’s ‘keyless go’ is standard, but we couldn't see the zip-up dashboard cover like on the concept car, forum watchers take note!
What's the 2012 Toyota FT-86 like to drive?
It’s great fun. There’s fantastic throttle response, quick, well weighted steering and a nice firm brake pedal. Add little inputs to the steering when you’re driving in a straight line at speed and the front end darts immediately – no slop, no roll, it’s just 100% obedient and alert.
Clearly, it’s not a GT-R chaser, but that’s the whole point – the focus here is on dynamics you can explore at lower speeds. The flat-four zings happily and spins round the dial to 7500rpm, at which point you get a flashing light and a well-judged soft rev limiter – not a sudden cut-out. Doesn’t sound much like a flat-four though – perhaps this is intentional, as the flat-four sound is such a Subaru trademark.
The gear ratios are closely stacked, and help to keep this modestly powered 2.0-litre spinning, but the ratios are well chosen so as not to be tiresome: 60mph in sixth gear brings up 2500rpm – relatively high, yes, but not daft. The gearshift could be slicker, but the lever has an engagingly short throw.
Even without sliding it around, the FT-86 is very obviously rear-wheel drive: get to the limit in a second-gear corner and accelerate harder and you feel the back end point the front back exactly where you want it. It responds well to a really aggressive driving style. Shame that the stability controls’ Sport setting was too intrusive, although Toyota’s engineers said they had a less intrusive set-up that they were also experimenting with.
It must be a blast to slide around…
Drifting is a huge part of the appeal of the FT-86, just as it continues to be for the AE86. Our car was fitted with 215/45 R17 Michelin Green X tyres all round – aka Toyota Prius tyres. This made it laughably sideways in second gear, the back end stepping out with relatively mild – and sometimes almost no – provocation. For the average driver, this makes exploring the limits far easier than in anything else currently on sale.
However, at higher speeds I found the balance less pleasing. In fast third-gear turns, for instance, the front end feels too soft and errs towards understeer – it could be pointier, firmer and more positive. Under provocation, the rear then comes around, but the FT-86 is so short that this transition can be very quick. Two factors then come into play: the first is the Torsen diff, which is more refined in day-to-day driving, but less precise than a mechanical differential when the rear tyres are struggling for purchase, so the level of control you have over the sliding rear end is compromised; the second point is the lack of power: adding power during slides helps you to bring things back under control, but in a high-speed FT-86 you’re more in the hands of momentum than you are able to dictate things with the throttle.
So the FT-86's a hooligan oversteer specialist?
At one point I found myself snapping into very fast oversteer, then suddenly snapping back and making an out-of-control excursion across the run-off area. My mistake, yes, but I’ve never had this feeling in any other modern rear-wheel drive car, 911 GT3 included.
Is there going to be an FT-86 with more power and a mechanical differential?
Turbocharging the flat-four would be straightforward (after all, that’s what Subaru does with the Impreza), but chief engineer Tetsuya Tada told us that he ‘doesn’t like turbos’ and has ‘decided to reject the numeric power war’. He also said that an R version of the FT-86 was coming with less weight, Brembo brakes (our test car’s stoppers were from Hitachi), a rollcage, a larger rear wing, no rear seats and, yes, a mechanical LSD but no more power.
And bear in mind that Toyota had invited us for our input and that this was a fairly early car – things will be tweaked for production. Our cars were still disguised, although pictures of the FT-86 production car have leaked out in recent days.
Other options are also on the cards: a convertible is ‘possible’, while an auto gearbox is confirmed – it’s a six-speed unit based on the eight-speeder in the high-performance Lexus ISF.
Verdict
The Toyota FT-86 is great news for enthusiasts: it’s affordable, frugal and relatively practical. You also don’t have to be a driving deity to explore its limits. If anything, we’d adjust the high-speed, on-limit balance (firmer front end, more progressive transition into oversteer, tighter differential), but that doesn’t undo the underlying fact that this is a great car, and one that trounces its closest rival, the Mazda MX-5, in the fun stakes.
Name:  Screen Shot 2011-10-28 at 6.19.41 AM.jpg
Name:  Screen Shot 2011-10-28 at 6.19.34 AM.jpg
http://www.carmagazine.co.uk/Drives/...2-CAR-review-/
Gabbo1976 is offline   Reply With Quote
Old 10-28-2011, 10:11 AM   #2
kaivo
Drives: -.-
handling only 3 stars ?:/
kaivo is offline   Reply With Quote
Old 10-28-2011, 10:12 AM   #3
DC87
DC87's Avatar
Drives: Pug
Just got tweeted this by Toyota EU, very interesting read. Again, no massively new facts but good to read a hands on review rather than just speculation over looks and figures.
He does note that "the engine does benefit from Toyota’s D4S direct injection, which helps towards a C02 figure of around 160g/km – a similarly powerful Renaultsport Clio manages 190g/km", not exactly the sort of figures we want to be hearing about but its something! Hopefully means it won't piss petrol in the way some sports cars do...
DC87 is offline   Reply With Quote
Old 10-28-2011, 10:29 AM   #4
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
170 lb ft? And it trounces a miata in the fun to drive arena? I would be highly impressed if this is true.
SUB-FT86 is offline   Reply With Quote
Old 10-28-2011, 10:35 AM   #5
Gabbo1976
Drives: Golf GT-TDI
Yeah 3 stars is poor considering the low centre of gravity and all of the testing put into this car running it alongside the Porsche Cayman. Oh well hopefully like Car Magazine state this was an early test mule and things have been tweaked for production.
Old 10-28-2011, 10:43 AM   #6
Enzie
Drives: 2011 Scion tC
I'm sure stuff has changed with the handling, because they got the car in May, and 4 months have passed. and during that time they've been to the nurburgring and did that nurburgring race. i'm still hopeful
Enzie is offline   Reply With Quote
Old 10-28-2011, 11:06 AM   #7
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
160 g/km = 34 mpg? Did I run that conversion correctly? 170 lb-ft is 458 territory right?
MannyO is offline   Reply With Quote
Old 10-28-2011, 11:09 AM   #8
BMWDAD
Drives: 2008 BMW 335i coupe
BMWDAD is offline   Reply With Quote
Old 10-28-2011, 11:09 AM   #9
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
I like the sounds of this, and im sure some handleing bugs have been worked out since then, plus coilovers will be one of the first mods I do anyways.
mkivalex is offline   Reply With Quote
Old 10-28-2011, 11:11 AM   #10
keiri
Toyobaru Wonder Twins™
keiri's Avatar
Drives: 2020 Subaru BRZ Limited w/ PP
The torque number sounds lovely, and surprisingly matches the Car and Driver estimation, and in line with what would be a good kick compared to what I'd driving now.
As far as the 160g/km goes I think that's a carbon dioxide emission measure so that's 160 grams of CO2 per 1 kilometer driven. I think. So I could be way off.
keiri is offline   Reply With Quote
Old 10-28-2011, 11:12 AM   #11
BMWDAD
Now I DO NOT have to buy a Miata ND to have some serious fun.
For me it is the BRZ vs the BMW 2 series coupe (no pics yet)
Old 10-28-2011, 11:14 AM   #12
Buggy51
Drives: Put Put
Maybe I'm the only one that's actually curious (I think everyone else is ), but... :P
"it’s a six-speed unit based on the eight-speeder in the high-performance Lexus ISF."
Huh, I wonder how that feels like.
Buggy51 is offline   Reply With Quote
Old 10-28-2011, 11:14 AM   #13
40flash
John 1:12
40flash's Avatar
Drives: Pearl white BRZ Limited
The platform is going to be great. We all know there will be tons of aftermarket handling stuff available right? If you aren't completely happy with the way it handles, change something. I bet at least 75% won't remain stock anyway. I wouldn't sweat the handling comment at all. As the others have said. The test mule was driven and written about months ago.
40flash is offline   Reply With Quote
Old 10-28-2011, 11:16 AM   #14
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
Yes, 160g/km is only CO2 emissions, but it means that the engine is efficient regardless. Lower CO2 usually means less fuel burned but has no direct relation of actual MPG.
This review is really exciting. A few things stand out: Toyota had better make the nannies completely defeatable; I want to turn TC and SC OFF for winter time shenanigans. Also, I find it odd that they say it trounces the MX-5 and then give it 3 stars for handling. The MX-5 is one of the best handling cars in terms of driver feedback and predictability. But it's certainly high praise for a test mule. And this 'R' version that he spoke of, I want the Brembos and the mechanical LSD but none of the other stuff.
I just can't believe that there isn't an NDA on this sort of thing. Hyundai had a complete NDA on driving impressions on the Veloster until the day it was released. The fact that they've published this really surprises me.
no_name is offline   Reply With Quote
brz review, fr-s review, fr-s reviews, ft-86 reviews, scion fr-s review, scion fr-s reviews, subaru brz review, subaru brz reviews, toyota ft-86 review, toyota ft-86 reviews, toyota ft86 review
First Spy Pics of Scion FR-S / Toyota FT-86 Production Test Mule! (Updated 5/17) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 495 08-14-2020 08:15 PM
Autocar's Toyota FT-86 / Scion FR-S First Drive Review Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 128 10-31-2011 04:57 PM
Scion FR-S Cover Article in new Road and Track Magazine Maxim Scion FR-S / Toyota 86 GT86 General Forum 314 08-30-2011 11:14 PM
Scion or Toyota ? 2jz-gte4life Scion FR-S / Toyota 86 GT86 General Forum 27 11-29-2010 09:56 PM
Tell Toyota we don't need Scion FT-86 Dark Scion FR-S / Toyota 86 GT86 General Forum 28 10-15-2010 08:26 PM
