Old 10-31-2011, 06:14 PM   #1
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Subaru GT300 engine
This popped up on the Subaru Motorsports blog and I thought it is pretty relevent to the ft86. You might've seen the diagram posted before of the Legacy GT300 car.
This has mainly been brought up to show how the AWD is set up, and how that might be possible in the future on the ft86, but one thing I never considered is that the engine is also very low and mounted far back... like the ft86. So in theory an EJ20 swap could look very similar to this.
The EJ20 type horizontally opposed engine - the only four-cylinder turbo engine in the 2011 SUPER GT, has been tuned for optimum performance on racing circuits by applying technologies continually developed for the WRC since the 1990s.
The engine block has the same shape as the road car version but doesn't have a sump to collect oil. A dry sump system, which has an external reservoir for oil, has been employed instead in order to lower vehicle height as much as possible. Oil is thus forcefully circulated by scavenge pumps mounted on the underside of the engine.
An induction box to conduct fresh air, a turbocharger to compress incoming air, and an intercooler, which cools down the compressed air, are all placed at the very front of the body. Both the length and layout of the exhaust pipe between the engine and turbo unit are designed for optimum shape for GT racing.
The most distinctive features of the 2011 power unit of the Legacy GT300 are the changed position and shape of the intercooler and added induction box, which leads fresh air directly from the grille to intake. In the 2010 model, air was fed in from behind the headlights.
you can read more about it here
http://www.subaru-msm.com/global/SUP..._explain.html#
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 10-31-2011, 06:32 PM   #2
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Front propeller shaft rather than transmission to wheel via axle shaft...
so thats how they can push back the engine and transmission while retaining AWD.
I wonder what kind of losses are expected and what kind of devices/materials used to compensate for it.
WingsofWar is offline   Reply With Quote
Old 10-31-2011, 07:36 PM   #3
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
AWD in the FRS/BRZ would be stupid, FYI.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 10-31-2011, 08:26 PM   #4
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
AWD won't happen anytime soon, but the turbo up front I do expect. There will be less room behind the motor so a front mounted location is more likely IMO.
Kostamojen is offline   Reply With Quote
Old 10-31-2011, 09:09 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Sorry, but this topic have been discuss before
Old 11-30-2011, 11:06 AM   #6
AaronCompNetSys
AaronCompNetSys's Avatar
Drives: 01' S2000; 05' WRX
My how those race car engine pictures are sexy. I think the BRZ GT300 will get this.
Pardon my trouble, but I'm not finding the front diff and drive shafts in that photo?
AaronCompNetSys is offline   Reply With Quote
Old 11-30-2011, 11:46 AM   #7
Dragonitti
Sweet design. Those concerned with weight additions of a turbo system, shouldn't if it's designed in this same fashion. The weight would be positioned low thus keeping that cod low. Only issue would be the hassle of installation under the engine. Hope you can just lift the car and not have to remove the motor like you have to with the 350z's VQ to install twin turbos.
Old 11-30-2011, 11:53 AM   #8
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
The pics are just of the engine. I was just saying the engine could easily be put in the BRZ, not the AWD system, and it seems pretty likely that's exactly what they did with the BRZ GT300.
Old 11-30-2011, 02:34 PM   #9
AaronCompNetSys
Something may be amiss here.... I'm thinking this is the BRZ GT300 engine bay! This would confirm that it is RWD only, with the motor psuhed back significantly more than the street car.
Originally Posted by Spaceywilly View Post
I just don't see how this is the Legacy bay, with its AWD. The damper is in the way.
I think this is the Legacy engine bay, with its horizontal dampers (it also has them at a goofy angle in the back).
Please forgive me if this was posted elsewhere.
Old 11-30-2011, 02:51 PM   #10
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
It is definitely the Legacy. You can see the grill of the legacy and the photo has been around for years.
Old 11-30-2011, 03:03 PM   #11
AaronCompNetSys
Ah, so the photos and diagram just don't go together. The engine shots are from the RWD Legacy, and the diagram is from the AWD one.
Source: http://en.wikipedia.org/wiki/Subaru_Legacy#Super_GT
Since they switched to RWD and got some wins, I would assume that it means the benefits of AWD were not good enough to keep, watering down the chances of the BRZ getting AWD.
Old 02-09-2012, 04:17 PM   #12
shadow explorer
shadow explorer's Avatar
Drives: N\A
Sorry to hijack the thread
I would kindly like to ask if there is any info or diagrams\sketches for a suspension system like that and how it works
shadow explorer is offline   Reply With Quote
Old 02-09-2012, 04:49 PM   #13
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It's just a basic push-rod suspension. Google will get you many explanations.
old greg is offline   Reply With Quote
Old 02-09-2012, 05:27 PM   #14
shadow explorer
Drives: N\A
Very kind of you,I will look it up
This is what I'm up to btw^^
http://farm8.staticflickr.com/7044/6...cd9d41ff_b.jpg
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 02:02 PM
Any issues with Subaru engine? CyberFormula Engine, Exhaust, Transmission 10 06-26-2010 06:02 PM
