Old 11-02-2011, 03:13 PM   #1
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build?
Hey, guys.
See Here: http://www.ft86club.com/forums/showthread.php?t=2131
Now we know the Compression ratio is 12.5:1
This is a nightmare for people who want do a turbo or a super charger build.
According to my knowledge, there are some ways that we could reduce the CR. I want discuss with you guys.
First, get a thinner gasket. This only can reduce a little CR, for example 0.2 or 0.3. Even we drop it to 12:1 its still not good.
Second, get after market pistons, rods. I think this is the best way to reduce CR, we may could reduce it from 12.5:1 to 11:1 or 10:1. But if we want crazy high boost...
Last, engine build. A whole new block? If you got tons of $$$ then go for it.
Those are just my thoughts based on my own knowledge, I didn't do a lot of search, so correct me if I'm wrong.
BTW, intercooler, BOV, waste gate, piping, turbo will those destroy the balance of the car? I don't know, looking for answer.
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 11-02-2011, 03:20 PM   #2
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
Also, what about freeing up horsepower in N/A form?
If an intake, and exhaust can get us 220hp i'll be happy with that, but would much prefer 250+hp with FI
KaliKev is offline   Reply With Quote
Old 11-02-2011, 03:26 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thinner head gaskets will RAISE compression, not lower it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 03:36 PM   #4
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
^ yeah you want a thicker gasket, but realistically it doesnt warrant a very good CR gains or losses.
On that note.. Boxer engines are a bit funky with gaskets
EJ251-Ej255 gaskets are thinner than EJ257 STI headgaskets.. BUT EJ257 gaskets give a HIGHER compression ratio to the same blocks....weird right?
WingsofWar is offline   Reply With Quote
Old 11-02-2011, 03:39 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I don't know EJ stuff at all, but what else is different? Or does just changing gaskets increase it?
There's something else involved there because and thinner but otherwise identical gaskets will always increase compression...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 03:39 PM   #6
Nurburgring
Drives: S2000, AE86, RSV10000R, 911, EP91
Do some research on boosted S2000's. It has been done a thousand times on totally stock engines, with 11.7:1 compression ratio. Results are impressive (420whp @ 12 psi for your typical bolt-on turbo kit using 93 octane, easily 500 with E85). A thicker headgasket is a bad band-aid, if you want to go high boost better build the engine and use lower CR pistons.
The biggest enemies on boosting this car will be:
- DI head (complexity, tuning)
- Space / packaging
- Lead time to having a decent standalone system available
Nurburgring is offline   Reply With Quote
Old 11-02-2011, 03:47 PM   #7
fred_boosted
- DI head
- Space / packaging
Nice tip!
What about mill the block? Is this safe and not that costly?
A set of after market pistion+rod. But those are just over my budget limit.
I'm considering an used BMW M3 E90/92 now... which is... shame..
But I gived up.
Old 11-02-2011, 03:48 PM   #8
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
DI doesn't have any negative effect on boosting anything... At this point the 12.5:1 compression is pretty much the worst thing they could have done. It's going to necessitate one of 2 things... Either Meth/H2O injection or Ethanol or both. But even then I'm guessing that you are only going to be able to run like 8PSI... but you will get good power.
The only good thing about that is... the engine will have a fully forged lower end... It really almost has to... 12.5:1 at 8k rpm or however fast they want to spin this thing... it has to have a forged lower end
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 03:56 PM   #9
Allch Chcar
Drives: N/A
Originally Posted by fred_boosted View Post
Hey, guys.
Kindly, you are not knowledgeable enough to speak on this subject at all.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-02-2011, 03:58 PM   #10
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
STI runs forged cranks and rods factory, if anything id expect this car to have a forged crank since its expected to perform in the upper registries of the RPM range.
Old 11-02-2011, 03:59 PM   #11
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
You don't have to be a **** about it.
Old 11-02-2011, 04:12 PM   #12
fred_boosted
Yes I'm not, just want begin to talk this topic.
And listen to adivces.
Why can't you just say why I'm wrong and tell us how to do thing right?
But I gived up.
Old 11-02-2011, 04:13 PM   #13
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Just a thought Fred...maybe this might not be the car for you! How about drive it first before deciding if it needs more power. My .02
Old 11-02-2011, 04:18 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Nice tip!
Milling the head and or the block will also increase compression. You want more room in there instead of less
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 09:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 10:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 05:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 10:46 PM
