Old 11-05-2012, 11:04 PM   #1
Ahz
Drives: None
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors?
I'm now using new wheels w/snow tires and didn't bother buying a new set of sensors for these wheels. The odd thing is that my FR-S which is listed to include TPMS in my country, doesn't fire off a warning that I have no TPMS?
Technically I shouldn't be complaining that I don't have to cover up the nag light, but I'm concerned about the system working. Has anyone else experienced this?
FYI, the original wheels are in the same garage with the car overnight, but I have gone up to 12 hours away from home in a day and still no light.
Ahz is offline   Reply With Quote
Old 11-05-2012, 11:17 PM   #2
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
I'd imagine the TPMS doesn't fire off a bad signal unless pressure is too low. So test it out and bleed out one of the stock wheels and see if the light pops up then.
Xanatos is offline   Reply With Quote
Old 11-05-2012, 11:34 PM   #3
wheelhaus
wheelhaus's Avatar
Interesting, so whether the TPMS sensor is there or not, it may not matter until one sends a low pressure signal.
wheelhaus is offline   Reply With Quote
Old 11-05-2012, 11:50 PM   #4
cnk
Drives: '13 DGM BRZ Limited
I swapped to winter rims/tires last Friday and took a drive that night and the TPMS light went on after about 20 miles so it does matter if the TPMS sensor is not there. Honestly though, even with the light on, it only was annoying when it was blinking. Once it went solid, I didn't even notice it.
cnk is offline   Reply With Quote
Old 11-05-2012, 11:55 PM   #5
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
This has already been covered in other threads but as far as anyone has been able to tell it takes about 30 min of continuous driving out of range of the sensors to trigger the system. The Toyota sensors that are being used don't require wheel rotation to trigger them. They pulse out at a regular interval unless they sense a rapid change of pressure which will cause them to immediately transmit.
If you have the tires stored near the car it's probably just reading them when you first start the car and you're not driving far enough for the system to,notice they are missing. At some point the light will probably come on, but next time you drive it may be off again.
Old 11-06-2012, 12:44 AM   #6
Future
Future's Avatar
Drives: BRZ!
I've been driving my BRZ all summer with aftermarket wheels without tpms, and never had a tpms light...
I know FRS do light up, but I have yet to find a canadian BRZ with a tpms light.
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 11-06-2012, 01:17 AM   #7
cnk
Are you sure the Canadian cars come with TPMS then?
Old 11-06-2012, 09:14 AM   #8
maxov
Drives: raven fr-s
i installed my new tire without any tpms sensor on it on my canadian fr-s that have tpms the only time the light appeared was at 0 degre celsius the computer send a request for the info about the pressure and didnt see anything but today at -6 i dont have any tpms light appear in my dash it's a good thing if he dont send any error if no sensor :P
maxov is offline   Reply With Quote
Old 11-06-2012, 09:14 AM   #9
maxov
Drives: raven fr-s
canadian fr-s have tpms and canadian brz dont
Old 11-06-2012, 09:25 AM   #10
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
If you drive for longer than a 50 mile stint at a time (roughly), the light will come on. When I had my summer wheels on, the light would stay off until I had been driving for more than a short distance.
Sent from my SPH-D700 using Tapatalk 2
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 05:22 AM
Update on TPMS - No light without sensors! trueno86power Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-11-2014 04:45 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 02:22 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 05:24 PM
How to get rid of those Pesky TPMS Sensors! rL-gT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 07-27-2012 09:53 PM
