Old 11-06-2012, 02:30 AM   #1
delusional
B R Z
delusional's Avatar
Drives: BRZ 6MT Limited
BRZ Driver's Door Courtesy Light Won't Work
I tried changing my driver's door courtesy light to LED and i think i shorted it. the socket won't light up and bulb i put in now. did i blow a fuse or something? how would i go about fixing this? thank you.
delusional is offline   Reply With Quote
Old 11-06-2012, 11:49 AM   #2
delusional
B R Z
delusional's Avatar
No one knows?
Old 11-06-2012, 11:49 AM   #3
cnk
Drives: '13 DGM BRZ Limited
Did you try flipping the LED bulb around?
cnk is offline   Reply With Quote
Old 11-06-2012, 11:53 AM   #4
delusional
B R Z
delusional's Avatar
Yup. I've even tried putting stock bulb back on and nothing works. Even though it works on the other door.
Old 11-06-2012, 12:37 PM   #5
cnk
Someone else had a similar issue but they never posted an update on whether they solved it or not. You may want to ping them.
http://www.ft86club.com/forums/showp...1&postcount=50
Old 11-06-2012, 12:41 PM   #6
xxscaxx
Drives: 2013 SWP BRZ
OP,
I had the same issue. Sorry to say, you are going to have to bring it into the dealership. They ended up replacing the BUI unit.
You can check the fuses first if you want, which are located underneath the dash on the driver side, on the left. Get your head under there and you will see a white plastic looking cover. Go into your car manual and look up the courtesy lights to find out what fuses it would go under ( can't remember at the moment).
My buddy who works at the dealership said there were only 2 available BUI units in the system, so i'd check this immediately and if its not the fuses, get your car into the dealership asap.
xxscaxx is offline   Reply With Quote
Old 11-06-2012, 12:43 PM   #7
delusional
B R Z
delusional's Avatar
Ill give it a try. Thank you so much.
Originally Posted by xxscaxx View Post
OP,
Ouch I hope I don't have to get anything major replaced. I will check the fuse box soon.
Old 11-06-2012, 12:48 PM   #8
xxscaxx
its a plug and play unit thats underneath your steering column, so its nothing major, but unfortunately I had to be a guinea pig of what the issue was. It was a few hours to swap out only because that BUI controls the alarm system and a bunch of other things and it was a process to re program the keys and such.
Old 11-06-2012, 01:41 PM   #9
delusional
B R Z
delusional's Avatar
sounds kinda bad did they charge you for it or was it under warranty?
Old 12-04-2012, 08:18 PM   #10
subiestar
Drives: CBS Limited BRZ
My issue is the opposite. My passenger courtesy light won't turn off. That's right, it stays on the whole time even with the door closed. I checked all my fuses, and I even checked the bumper on the door chassis that activates the window and light when you open the door.
I'd like to hear a followup from xxscaxx about that BUI thing.
subiestar is offline   Reply With Quote
Old 12-05-2012, 03:55 AM   #11
jpit
Drives: Subaru BRZ
I have the same problem. Passenger courtesy light will not turn off. I put in new speakers and thought I had screwed something up but now I wonder if it is the BUI problem.
jpit is offline   Reply With Quote
Old 02-22-2013, 10:21 PM   #12
wrohdejr
Drives: 2013 subaru limited wrb brz
i just had the same thing happen with light not turning off. How much did you have to pay to get the bui replaced. I know they will not cover this under warranty because i attached a door led projector to the bottom of the door and tried to wire it into the door courtesy light. The will be able to see that i created the problem.
wrohdejr is offline   Reply With Quote
Old 06-24-2013, 11:44 AM   #13
sdsubie
Drives: 98 Outback, 13 BRZ
Just following up on this thread. I installed door courtesy lights from one of the vendors here, and now the passenger courtesy light won't turn off. Did you guys ever find out a resolution for this issue?
sdsubie is offline   Reply With Quote
Old 06-24-2013, 12:17 PM   #14
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you read all posts, BUI needs to be replaced
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Driver's door rattle TuxedoCartman Scion FR-S / Toyota 86 GT86 General Forum 38 07-31-2013 10:34 PM
FRS door marker light question Alalbaster Krunnk Cosmetic Modification (Interior/Exterior/Lighting) 3 08-22-2012 02:09 PM
Door Light - After the part number for this DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 0 07-07-2012 04:49 AM
