Old 11-07-2012, 01:55 AM   #1
NetMagi
NetMagi's Avatar
Drives: 13 Firestorm FR-S
Cold-weather morning shifts
Some advice for those with the 6-speed manual on your morning commute when the car is C-O-L-D: Double-clutch
That "hard to slip in" 1-2 shift becomes silky smooth, even when the gearbox is ice cold.
Give it a try
-Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S
NetMagi is offline   Reply With Quote
Old 11-07-2012, 09:05 AM   #2
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
I don't have the 1-2 problem people seem to have. What I do have is reverse, it's hard to throw into reverse when cold.
Asphaltfrs1 is offline   Reply With Quote
Old 11-07-2012, 09:14 AM   #3
Ben_G
Drives: Blue BRZ
Give it a try
-Rich H.
I already found that double clutching works, but it still takes some effort if you left 1st gear at a higher RPM....
I'm beginning to dread what shifting may be like when it's mid February and i'm leaving the house at 5 a.m after being parked outside all night...
Ben_G is offline   Reply With Quote
Old 11-07-2012, 10:04 AM   #4
gmookher
http://www.ft86club.com/forums/showt...t=16604&page=7
gmookher is offline   Reply With Quote
Old 11-07-2012, 10:15 AM   #5
#87
I usually post drunk
#87's Avatar
I live in residential area and have to go through several stop signs on cold engine and trans.
First gear is notoriously hard to shift into from stop signs. Double clutch helps but doesnt eliminate it. Annoying but not a big deal. Funny I let someone drive my car and they were like I can't get into first, lol
#87 is offline   Reply With Quote
Old 11-07-2012, 10:29 AM   #6
camelflage
Drives: pinto power
it seems hokey, but .... http://cozywinters.com/shop/kh-1000-1020.html
camelflage is offline   Reply With Quote
Old 11-07-2012, 10:44 AM   #7
Ingen
Drives: Ultramarine FR-S 6MT
I've found reverse behaves slightly better in the morning if you let the car warm up slightly, then go 1st --> 2nd --> reverse. It seems to sync up a lot more frequently when I do that, as opposed to preventing me from shifting in at all.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 11-07-2012, 10:55 AM   #8
Jayde
Jayde's Avatar
I generally let my car warm up for 5mins or so, regardless if there is ice on the windows or not now. I like to let the RPMs dip below 1,000 and have the temp gauge read at C (cold is past c) before setting off. Very rare that the first shift to second is a problem.
Jayde is offline   Reply With Quote
Old 11-07-2012, 10:59 AM   #9
DarkSunrise
DarkSunrise's Avatar
I've been noticing my 1-2 shift getting difficult as temps have been dropping. In the first 2 minutes of driving when temps are below 40 F, 2nd gear feels locked out completely. Can be annoying until the transmission warms up.
Old 11-07-2012, 10:19 PM   #10
TurnOne
Drives: BRZ Ltd. WR Blue 6MT
I raise the rev's a little and it slips into 2nd easier.
TurnOne is offline   Reply With Quote
Old 11-07-2012, 10:46 PM   #11
White Shadow
Drives: 12,000 miles per year
Give it a try
-Rich H.
That's because double-clutching takes the synchronizers out of the equation. But it's still a good idea if you don't mind the extra "work"
Another option is to just swap the gearbox oil to something that flows better in cold temps. Personally, I've been a big fan of using Redline MTL in several of my past stick shift cars. It makes winter driving such much nicer.
White Shadow is offline   Reply With Quote
Old 11-08-2012, 12:05 PM   #12
Dezoris
Dezoris's Avatar
Change to a proper manual trans fluid and shifts are no longer an issue in cold or hot.
cold weather & remote starter jarviz Scion FR-S / Toyota 86 GT86 General Forum 16 11-10-2012 07:03 AM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 12:42 PM
Pretty sure car hates the cold weather HuntingtonFRS Issues | Warranty | Recalls / TSB 28 10-21-2012 05:52 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 01:24 AM
you can see how fasts the shifts are in this vid! its quick!!! carbonBLUE Engine, Exhaust, Transmission 24 04-03-2012 08:25 PM
