Old 11-07-2012, 07:51 PM   #1
DatGoodBRZ
Drives: 2013 SWP BRZ Ltd.
Awful grinding!!!
Idk.... Has anyone else gone up a steep driveway/entrance at an angle and heard a grind? It seems to cause my traction control lights to flash and I hear a grind! It's not the bottom of the car scrapping either. The incline is not crazy steep either. Just seems lik when takin the angle to clear the front bumper and the car sits more on the 3 wheels goin up that I hear this grind. Just wanna know if anyone else has run into this problem or a possible defect with the car!
DatGoodBRZ is offline   Reply With Quote
Old 11-07-2012, 07:55 PM   #2
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
It's one of your wheels spinning and trying to gain traction. Due to the LSD's in our cars, when one of the wheels looses traction, espeically going up an incline or a drive way that is uneven, the LSD makes the wheel with no traction fight for traction and sometimes can sound like a grinding/rubbing noise. That's what my guess would be if nothing like your body is scraping on the ground.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 11-07-2012, 07:56 PM   #3
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
cant say i do. the flywheel/clutch rattle at very low rpm is normal for a lightweight clutch im not sure if this is car comes with a dual mass flywheel but it could be the diff locking. going on the incline. not sure though havnt had my car make any noises other than the low rpm flywheel rattle sound. which my M3 did at low RPM.
DanoFA20 is offline   Reply With Quote
Old 11-07-2012, 08:21 PM   #4
DatGoodBRZ
Thanks! Yea not a scraping sound. More of a grinding sound. I avoid putting my car in that angle anymore so can't say for sure where it's coming from but it does hurt my stomach when I hear it. I was goin really slow as to not scrap the car but the first time I heard it I had the radio on. The next time I really heard it and it scared the crap outta me! Then again when goin in the entrance of a store. That is when I knew for sure my car doesn't like taking steep angles!
Old 11-08-2012, 01:09 PM   #5
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
If the wheel slip light is coming on it sounds like the traction control is turning on and thats the grinding you hear.. It is fairly abrasive sounding.
Ranatsu is offline   Reply With Quote
Old 11-08-2012, 01:15 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you're losing traction going up whatever this incline is. Maybe it's slippery (pothole, uneven surface, gravel, imbeded oil, etc)
and your traction control is turning on
what you are hearing/feeling is.. traction control
welcome to the 21st century.
Old 11-08-2012, 10:49 PM   #7
DatGoodBRZ
Wow thanks! Yea I've never had a car with traction control lol!
Old 11-09-2012, 12:26 AM   #8
DanoFA20
Shift Down
DanoFA20's Avatar
also remember keeping any tcs will also effect tire wear. turn it off you have less wear on tires.
Old 11-09-2012, 01:35 AM   #9
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
.. But sometimes much more wear on the car when you hit things.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 11-09-2012, 08:03 AM   #10
DanoFA20
Shift Down
DanoFA20's Avatar
If your car loses traction that just to me means you're driving like a moron or way too fast and don't know your own limitations . All my rear wheel drive cars never came with traction control or vehicle stab. My foot is my traction control connect the link from brain to foot. Don't ever rely on a computer dude. The only time you should need traction control is in the rain or snow .
If you also ever want to track the car you'll limit your cornering because you're relying on tcs to keep you from sliding this is a mistake . Op turn that crap off unless its necessary. �� If anyone doesn't agree sorry but I've never had tcs in my cars before and don't slide off roads or hit trees. Which shows tcs is a luxury but not a necessity. That's my out look on it.
Old 11-09-2012, 08:42 AM   #11
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Traction control effectively uses the rear brake to give traction to both wheels when one is off the ground, that means it will be HARDER to climb up a slanted driveway with the electronics off. The LSD does not work with only 1 wheel with traction. The grinding sound is the ABS pump.
Rayme is offline   Reply With Quote
Old 11-09-2012, 09:35 AM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so the Williams FW14 was a shitty car then
stability and traction control on the STREET is a GOOD thing, i don't care how awesome your initial-d skills are, when you're faced with hundreds of unpredictable events during a daily drive it is good to have your CPU buddy watching over you.
Old 11-09-2012, 10:50 AM   #13
FRiSson
Drives: FR-S MT
Turn off the traction control and see if it still grinds. Then, report back to us.
FRiSson is offline   Reply With Quote
Old 11-09-2012, 05:13 PM   #14
DanoFA20
Shift Down
DanoFA20's Avatar
LAWL initial D skills
i dont mind tcs components its just nice to konw your vehicles limitations with them off people get to cocky behind the wheel and think tcs and vsc is going to make you godly. i just say learn the basics of the car raw. youll get a better understanding of how it works and feels mechanically. idk how to explain it, it makes sense in my head and while im driving someone else would describe this better id like to think.
and NOOO the FW14 was not a shitty car lol
Grinding / Shaking under emergency braking Kurenai Issues | Warranty | Recalls / TSB 16 11-05-2012 10:52 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 06:14 PM
Awful, terrible mistake... ShinyBRZ Scion FR-S / Toyota 86 GT86 General Forum 45 08-21-2012 12:35 PM
Manual grinding sound deedz Engine, Exhaust, Transmission 22 07-20-2012 11:05 PM
Awful Dealer Experience in Hollywood nyanpire Scion FR-S / Toyota 86 GT86 General Forum 251 06-30-2012 01:58 AM
