Kouki-Monster
1. What offsets are you using?
2. What tire size are you running in the front? 3. What is your suspension / alignment setup? 4. Finally .. got pictures? Cheers
Rich Anderson
EMPOWER AUTO |
Drives: Whiteout FR-S
I think you almost have to be on coilovers so they won't hit the strut, by my math you could probably do it with a +30 offset but that would poke a little more than i would want. I would think a +40 would look better but would require coilovers...
#3 | |
Kouki-Monster
I'm just trying to get as much info in before these wheels get bolted up next season.
Rich Anderson
EMPOWER AUTO |
I agree 225 is way too small for 9.5's. +38 on a 245 or even 255/35 should be good.
#5 | |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I have driven a set up with 18x9.5+30 running 225/40 and the poke was too much for my taste.
BRZ001: Peace Love and Wheelies @metabrz on IG
Drives: 2003 Subaru Outback
If youre gonna run a 9.5 wide, please put atleast 255's on them. idk why people love buying tires too narrow for the wheels. Just buy a more narrow wheel if you only want to run a 245 or smaller.
Drives: FR-S, NA8, S13
![]() 18x9.5 +25 225/40 (oh no!... must be because im butt hurt right?? ...)bc coilovers f: -3 0 toe r: -3 0 toe (more aggressive alignment is next, had a roadtrip to ohio so went conservative... will be getting rear arms instead of the whiteline bushes) you can run 235s on +30 in the rear. fronts can fit way more easier. if you are looking to fit tire though you will need to be in the high 30s or low to mid 40s in offset... but run the risk of touching inward. |
Drives: '13 BRZ in WRB--let's mod!!!
Guest
Posts: n/a
Most wheel faces only look good in the 9in+ versions ie RPF01, TE37s, Kiwamis etc. The car doesn't make enough power to overcome wide grippy tyres hence I have 225/40 on a 9.5+38 and looks and works great
#10 | |
didnt think id have to spell it out but i should have figured someone would have read it wrong and try and make me feel stupid about it. ![]() also, the big misconception about negative camber is that it will destroy tires... while it is true that it will have adverse effect on tire wear it wont be "eating tires". ( unless you are retarded and run like -6 degrees ) the combination of toe and camber will eat tires. my 8th gen civic si had -3 front and -2.8 rear camber, and even with bridgestone re01r (low 100s treadwear) the tires lasted extremely long (17k mi)... due to zero toe. only way it "eats tires" is if you are too stupid to have it aligned properly. ..and i wasnt saying conservative in regards to camber... i was speaking of toe. the car will be set up with more caster and toe out in the front for better response/turn in feel. rear will be left with zero toe as it already gets out enough as is. ( car is my DRIFT car.. NOT grip car. ) ill leave my thoughts out on your first comment because saying anything further about it would be petty on my part. |
#11 |
Drives: Toyota 86 GTS
Has anyone fitted 18 x 9.5 + 38 with lowering springs only???? Anyone know if it will fit?
I just ordered 18 x 9.5 + 38 and I am on Eibach springs only... will they fit? (concern is wheel touching spring) I want to run 245/35 on the front and 255/35 on the rear.. HEEEEELLLLLLLPPPPPPPP.. Unrelated but I can't post up a new thread? Any ideas why? |
#12 | |
Drives: '24 GR86
But you screen name is Stance86. Can't have that and run those weak offsets ![]() Ebphoto did it right. I still have yet to see one that looks as good as his.
#13 |
If you are talking about the Grids, that's what he is running in the rear, the fronts are 8.5's. I don't think 9.5 +38 will clear the factory strut up front.
#14 |
1337
Drives: 2013 BRZ WRB S/C
| Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 | RZ86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-18-2013 05:14 AM |
| Anyone running with Nitrous? | JDMenrique | Forced Induction | 29 | 10-21-2012 11:02 PM |
| what height are you running | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 0 | 09-28-2012 12:29 AM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 02:52 AM |
| Running 19's | SocalBurt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-04-2012 03:45 PM |
