Old 11-12-2012, 03:20 PM   #1
gt865
Drives: Scion
Warm Up?
Hey all, I just wanted to know how long you warm your car up before moving? I have always let the RPMs drop to about 1k, but i always wondered if it was necessary. Thanks in advance!
gt865 is offline   Reply With Quote
Old 11-12-2012, 03:23 PM   #2
Burrcold
Drives: Subaru BRZ Limited
Depending on outside temperature, I usually only wait about a minute. Obviously if it is dead of winter, I'll let it warm up more (but that's usually to allow for any ice to melt, and the interior to warm up). You obviously don't have this problem being in FL.
Old 11-12-2012, 03:38 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I like to let the engine go through it's fast-idle phase at startup. When the RPMs pop up and then settle down, I'll go.
Old 11-12-2012, 03:41 PM   #4
JSK
Drives: FRS Asphalt
^^^Same here. I find that on colder mornings this process takes a little longer so It compensates for the cold on its own.
JSK is offline   Reply With Quote
Old 11-12-2012, 03:47 PM   #5
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
A good indicator is to listen for the initial idle change. You it's ready to go by then. I perform this for my bike as well...there's truely a difference!
Yeah!, What J and D Rex said!
Wolfking is offline   Reply With Quote
Old 11-12-2012, 03:54 PM   #6
whaap
whaap's Avatar
Since I no longer live in the snow belt of our country I will start the car, put it in gear and gently drive away. The key word being gently.
If I lived where it really gets cold I would give it a moment to be sure lubrication is flowing and again gently drive away.
whaap is offline   Reply With Quote
Old 11-12-2012, 04:18 PM   #7
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I wait until the revs drop like everyone else seems to and then I drive it gently (<4000 RPM) until the engine temp is up to normal.
Flat Black VW is offline   Reply With Quote
Old 11-12-2012, 06:00 PM   #8
fatoni
i dont think in a modern car it is as imperative to wait for the idle to drop. modern oil and a modern engine really only need to get the oil flowing before you really get things going. i think this (along with the precision of machining) is why you see cars lasting longer and longer.
Old 11-12-2012, 06:12 PM   #9
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I have always waited at least 30 seconds for the engine to warm and the revs to drop to normal rpm. Then drive gently til fully warmed up.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 11-12-2012, 06:30 PM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
If i didn't drive the car for more then lets say 5 hours, I always let the car warm up for two minutes before rolling off.
I don't care if i'm driving the Audi or an old Alfa Romeo, i give it two minutes.
Old 11-12-2012, 10:48 PM   #11
getbent
Drives: 2013 FR-S Blue MT
I start it up, back out of the garage and try to keep it under 3000 rpm for about the first 10 minutes or so.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 11-12-2012, 10:52 PM   #12
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I always start up and leave, my last car i put 80k miles on it (152k when i sold) i would start it up, roll out of the driveway, 3k rpms, drop the clutch and race to work.... never had 1 problem...my car would never get warmed up by the time i got to work in the winter... lol
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 11-12-2012, 10:55 PM   #13
jmaryt
Drives: 2012 honda civic ex
about 10 seconds to make sure i got "pressure in the boat" then drive moderately until operating temperature is reached.
jmaryt is offline   Reply With Quote
Old 11-12-2012, 10:59 PM   #14
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
i usually let the car warm up for 3 minutes . oil needs to get to optimal running temp imo before really going.
DanoFA20 is offline   Reply With Quote
"vent" setting very warm to hot MTeator Scion FR-S / Toyota 86 GT86 General Forum 39 02-12-2023 10:35 AM
good warm-white LEDs? Elfreda Blau Cosmetic Modification (Interior/Exterior/Lighting) 0 08-13-2012 11:06 PM
a thought about the warm air coming from the vents... pr086 Scion FR-S / Toyota 86 GT86 General Forum 32 08-02-2012 11:06 AM
Warm vs cool Weather performance EsoBOFH Scion FR-S / Toyota 86 GT86 General Forum 22 07-10-2012 12:45 PM
