Old 11-14-2012, 01:10 PM   #1
Fugazi
Fugazi's Avatar
Drives: SWP BRZ 6 Speed Limited #888
Flat tire...replace or plug?
I am thinking replace it, what do you say? K I was told by my friend at Jax Subaru that patching should be okay if its not to close to the sidewall.. So I will have to check out where the nail was.
It popped right out but i saw the hole.. but cant remember the distance..
First injury to my brz
Fugazi is offline   Reply With Quote
Old 11-14-2012, 01:17 PM   #2
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Replace all four
Rayme is offline   Reply With Quote
Old 11-14-2012, 01:17 PM   #3
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
I'd say plug it yourself. Easy. $10 kit from Advance Auto or AutoZone.
jflBRZ is offline   Reply With Quote
Old 11-14-2012, 01:19 PM   #4
cnk
Drives: '13 DGM BRZ Limited
Depends on where the puncture is on the tire and the extent of the damage. For me, if it's something like a nail and it's not in the outer section of the tire, I would be comfortable with plugging it. If it's in the outer section of the tire, I would replace it only because there is more flex in that area when cornering and a higher chance of the plug failing.
cnk is offline   Reply With Quote
Old 11-14-2012, 01:22 PM   #5
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
On top of replacing all 4, buy 4 more tires just in case and 4 tpms sensors too!!!
I'll be back!!
F3dzo is offline   Reply With Quote
Old 11-14-2012, 01:26 PM   #6
Orthow
Drives: 99' SIR Kswapped Racer/Showcar
Option C) Repair tire (Assuming it's repairable) ; Replace tire ; Keep Repaired tire as spare
Orthow is offline   Reply With Quote
Old 11-14-2012, 01:29 PM   #7
whaap
whaap's Avatar
If it's just your basic nail in the tread type of flat I'd have no trouble using a plug. On a motorcycle I'd replace as soon as possible.
There's a lot of controversy about this. One theory that seems very true is that to put in a plug you first have to use a tool that forces the thread of the tire further apart so the plug can be made to go in the hole. If these threads are steel, over time they can act as a garrote and eventually cut into the plug. But, I'm inclined to say so what? From the inside of the tire you still have the head of the plug that is tightly pressed against the inside of the tire. If it did cause a problem further down the road you could always fix it again or replace it.
whaap is offline   Reply With Quote
Old 11-14-2012, 01:41 PM   #8
jstn
Drives: '15 Vortech Supercharged
Just patch it if it's not too close to the sidewall. I've autocrossed on two patched tires before, it isn't a big deal really. Wal-Mart will do it for 10-15 bucks depending on whether you drive in or just bring them the wheel.
jstn is offline   Reply With Quote
Old 11-14-2012, 02:00 PM   #9
Fugazi
Fugazi's Avatar
Originally Posted by ottopilot View Post
Replace all four
There is a option D replace the whole car, just to be safe...
Old 11-14-2012, 02:03 PM   #10
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Patching it if it's not too close to the sidewall. Just keep in mind patches can cause water to seep into the tire which raises your blowout chance. Also, if the tire is damaged from you driving on it or it's a run flat replace the tire.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 11-14-2012, 02:42 PM   #11
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
Plug it.
I have been driving around with a Tek Screw in mine for a month now. Too lazy to drop it off at Firestone to get it taken out and plugged - Thanks fro the reminder to get that done. Another reason why the BRZ will never be driven in here to work.
Dorb is offline   Reply With Quote
Old 11-14-2012, 02:44 PM   #12
tedward88
tedward88's Avatar
Drives: IS250 AWD
Soo...water would seep through before air leaks out?
to OP, patch it if its not too close to the side wall. Buy a patch kit or just bring it to a tire shop and get it patched.
tedward88 is offline   Reply With Quote
Old 11-14-2012, 03:10 PM   #13
gily25
Drives: Silica BRZ 6MT
Are you planning on replacing these anytime in the near future? If you're going to replace them in spring or within the next year, I would plug it and save the money for the upgrade.
If you're going to ride them until they need replacing then you may be more comfortable replacing the tire. Some shops (smaller local garages/shops) will give you a credit for a tire that can be plugged but you don't want anymore.
gily25 is offline   Reply With Quote
Old 11-14-2012, 03:32 PM   #14
White Shadow
Drives: 12,000 miles per year
The only way to really PROPERLY repair a punctured tire is to use a patch/plug repair. With this type of repair, the tire must be removed from the wheel. A one-piece patch & plug combination repair is made from the inside of the tire. The plug is pulled through the puncture and then the patch seals against the inside of the tire.
Don't get me wrong....I've used regular plug kits on my cars in the past and they've held up just fine. But I wouldn't do that with a performance tire or a high speed rated tire if I wanted to drive fast for any length of time. BTW, also keep in mind that most tires "lose" their speed rating if they've been punctured & repaired, despite the repair method. I believe there are some tire manufacturers that do consider a repaired tire to keep its speed rating if the damage is minimal and it is repaired to their own specifications.
White Shadow is offline   Reply With Quote
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 06:54 PM
Which ones do you like to replace the stock rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-11-2012 10:53 PM
Replace the speedometer for a gauge TIE Pilot Electronics | Audio | NAV | Infotainment 11 10-03-2012 10:19 AM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 03:57 PM
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 08:52 PM
