Old 11-15-2012, 11:54 AM   #1
Umbie
Umbie's Avatar
Drives: 2013 Subaru BRZ
Ordering Nameless Exhaust - Helmholtz Resonator??
After much deliberation, I have decided to place the order for a cat-back Nameless Performance exhaust. I have a few questions I was hoping you guys could help me out with:
1) WTF is a Helmholtz resonator, and more importantly, how does it effect the sound?
2) Do I need to order bushings with it? There is an option to add 2, 4, or 5 bushings.
3) I am ordering the one that replaces the overpipe. Has anyone installed this system? I don't think jacking the engine up 1 inch should be too difficult, but I would like to hear it from someone who has experience.
This seems to be the best exhaust in terms of sound and HP gain, but if anyone has any other suggestions, I'm open to it. I've already spent too much time in the official aftermarket exhaust thread!
Umbie is offline   Reply With Quote
Old 11-15-2012, 12:43 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
If you get this and get it installed can you post a few pics? I've read a couple of posts/reviews mentioning that the tips aren't even(one sticks out further than another). Not sure if it was an install issue or manufacturing defect, either way its really the only thing keeping me from buying their cat back system for the AT.
Sent from my iPad using Tapatalk HD
Freeman is offline   Reply With Quote
Old 11-15-2012, 01:19 PM   #3
Umbie
Umbie's Avatar
Okay, so after some research I've decided the helmholtz resonator is unnecessary. However, I am still unsure whether I should get the bushings (and how many) or just use the stock ones. Help?
Freeman, I WILL be getting this exhaust when I figure out these last few details. I hope to install it over this next weekend or the following, depending how long it takes to ship. I will keep you posted.
Old 11-15-2012, 01:24 PM   #4
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
I have the nameless exhaust and kept the stock bushings.
No issues whatsoever.
Luke.Cariveau is offline   Reply With Quote
Old 11-15-2012, 01:33 PM   #5
Umbie
Umbie's Avatar
Thanks, Luke! That's all I needed to hear. Order has been placed!
Old 11-15-2012, 01:35 PM   #6
Guillaume
Guillaume's Avatar
Drives: Exige S 240
http://lmgtfy.com/?q=helmholtz+resonator
Old 11-15-2012, 01:38 PM   #7
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
I'm using the stock bushing also. No issues either. I wouldn't go with the resonator unless I was going to run an unmuffled version of the axleback. They are used to remove drone ( resonance ) at a specific frequency. The muffled axle back does not have any, so really unnecessary.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 11-15-2012, 01:45 PM   #8
Umbie
Umbie's Avatar
Thanks, Neziah. I was pretty sure it was unnecessary but wanted to hear it from someone who already purchased this system. This is the first major modification I am making to the car, exciting stuff!
Old 11-15-2012, 03:09 PM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I ordered with Helmholtz, because one I don't want a loud car and two when I keep changing components (header) it will keep getting loud and I wanted it as quiet as possible.
I LOVE this exhaust. The sound is amazing. The installation is not hard, but be prepared and separate and hour or more if you are planning on doing it with a jack and stands. I did it by myself in about an hour and a half. To lift up the engine, there is a cross bar that has a transmission mount connected to it. You will see from below the car, there are two bolts connected to it (held by nuts). Loosen the right nut, and use the jack to lift the engine by the oil pan. you will have to juggle around to get that overpipe in, but its nothing hard. Good luck and ask away if you have questions.
Old 11-15-2012, 03:45 PM   #10
RYU
RYU's Avatar
Drives: really slow...
Helmholtz filters out a certain range of frequency. It is used in the exhaust world to cancel out drone frequencies which typically occur around 90-140hz. It does a poor job of actually changing the tone of the exhaust but is fantastic at cancelling drone (If calculated properly). Unfortunately it adds weight.
Here's an article I put together about exhaust design on another forum.
http://www.nsxprime.com/forum/showthread.php?t=146644
Read up and get ejumacated
EDIT TO ADD:
I used 1/4 wave resonators (similar to helmholtz) in my design here.
RYU is offline   Reply With Quote
Old 11-15-2012, 04:55 PM   #11
Neziah
Yep it is tuned, so if you keep adding changes to the system it may or may not work fully, certainly wont hurt anything. If you want to explode your mind, call up Jason and ask him to explain how it works. LOL
When I got to test their Dual outlet non-muffled Axleback on my FR-S, it would of been a perfect application for one as it had a drone at a very defined RPM range. They can cancel that out with the HR. Otherwise I loved it. Really had about the same sound as the muffled, just louder when you were on the throttle. I was surprised how quite it was at an idle. I am super happy with mine, but I was very tempted with the unmuffled.
HotLava FRS MT
Old 11-15-2012, 05:05 PM   #12
dabocx
dabocx's Avatar
Drives: Scion FRS
I regret not getting the Helmholtz resonator in my OP/DP.
dabocx is offline   Reply With Quote
Old 11-15-2012, 05:18 PM   #13
Umbie
Umbie's Avatar
Thanks for the help, guys! I do have a scissor lift so installation should not be too difficult. Not to mention I just swapped out the tranny in my Legacy and this should be a breeze compared to that PITA. My hopes are to do some other modifications during the winter and have an even more amazing car to drive come spring! I will keep you all updated.
Old 11-15-2012, 06:45 PM   #14
gonzo
Drives: frs
My tips are at the most 5MM off. nothing I can't fix, but I didn't even notice it until i stared at it for a few seconds
gonzo is offline   Reply With Quote
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 03:23 AM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 10:47 PM
Question about Nameless Performance exhaust Metallic BRZ Engine, Exhaust, Transmission 16 08-05-2012 10:06 PM
Exhaust baffle/ box structure between cat and resonator? ahausheer Engine, Exhaust, Transmission 14 04-25-2012 02:57 PM
