Old 11-19-2012, 02:43 PM   #1
ThePoet
Drives: Scion FR-S
BRZ Headlight Swap?
Has anyone successfully swapped a set of the BRZ headlights into an FRS? I would be really interested in doing this because I think the BRZ headlight design and LED DRL's look a million times better than the ones that come standard on the FRS. Anyone know if it would be too complicated to do?
ThePoet is offline   Reply With Quote
Old 11-19-2012, 02:46 PM   #2
Burrcold
Drives: Subaru BRZ Limited
http://www.ft86club.com/forums/showt...headlight+swap
Old 11-19-2012, 02:46 PM   #3
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
They look about 800 times better... Per side.
chulooz is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Where can i get this headlight? remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 16 10-25-2012 07:01 AM
Another Headlight Mod msile Cosmetic Modification (Interior/Exterior/Lighting) 25 09-09-2012 07:26 PM
HEADLIGHT HELP Roborat Cosmetic Modification (Interior/Exterior/Lighting) 1 08-06-2012 12:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 03:45 AM
