| DIY (Do-It-Yourself) Guides For all DIYs. |
#1 | |
@theexquisite86
Drives: 2013 Firestorm FR-S
how to turn that rear triangle reflector into working brake light
I found this how-to guide on his to do this here
But there is a couple things to add If you want your new brake light to stay lit and get brighter when brakes ar pressed connect to the wire that it shows in the guide, but if you want to have it only light up when brakes are pressed this is how Disconnect the 4 pin plug from the left brake light, peel back the plastic protector, find the solid green wire and that's where your positive wire needs to be connected, you can strip a little section and solder the wire to it or use on of those quick crimps. Also you do not have to pull the existing harness out the way he does just run your wires and zip tie or tape your new wires to the old ones The two silver screws on top of the reflector are a bit tricky to get but just work at it, they are 3/8in screws or Phillips screwdriver I also wired up a toggle to kill the light when I feel I dont need it just buy a basic toggle and cut your power wire, put some wire connectors that fit the toggle on each piece of the cut hook it up and your good to go I've completed mine and will add a link to a video when it's darker to show y'all mine Last edited by chris's fr-s; 11-28-2012 at 01:15 PM. |
Drives: Asphalt Scion Frs 6MT
Well there was a guy on here doing retrofits until the mods got overzealous and banned him.
I'll see if i can help you out
Drives: Don't have one
cool beans
STAGE 1
Drives: GT86/2T HONDA RUCKUS/86 HONDA SPREE
Very nice!
I Love custom Turbo kits
Drives: Limited BRZ
@theexquisite86
Good work. I'd honestly prefer turning it into a rain light for track use that flashes on it's own every .25 seconds. I assume the process would be similar?
Drives: Limited BRZ
Embedded:
![]() [ame="http://www.youtube.com/watch?v=ycS5aTbF9I0"]Scion fr-s backlight #2 - YouTube[/ame]
#9 | |
@theexquisite86
If you have any questions just pm me |
#10 |
Thanks when I start it I will contact you.
#11 |
Drives: BRZ Premium Black
Wait wait wait... You're from Beaumont, TX and you have a Québec license plate? lol
You sure travelled far to get screwed on taxes and registration fees. |
#12 |
Drives: 2013 Scion FR-S Asphalt
#13 |
@theexquisite86
#14 |
| ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! | ZILLA | DIY (Do-It-Yourself) Guides | 117 | 09-19-2017 11:17 AM |
| Third brake light not working....what should i do before bringing it in? | Hotlava86 | Issues | Warranty | Recalls / TSB | 11 | 03-10-2016 01:12 PM |
| Red triangle on rear, fog light? | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 12-22-2012 08:22 PM |
| rear triangle red light | ncbluefr-s | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-15-2012 12:46 AM |
| FR-S Rear brake light... | MF_DEUCE | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 05-05-2011 04:53 PM |
