Drives: LP DSP / CSP '13 BRZ
Crush Washer Sizes
I tried searching but no luck.
Does anyone know what size crush washers are used on the differential fill and drain plugs? I saw the oil plug is M16, are these the same? I really don't see the need to drive into town and pay a dealer when you can get them from the local auto parts store for $1. I'd just like to know which sizes to pick up ahead of time, instead of pulling it off and taking it up. Thanks! |
#2 | |
Drives: 4Runner
I just bought some from the local dealership for the diff. They were crush washers.
diirk
waiting on a Neptune Premium MT |
#5 | ||
I Love custom Turbo kits
Drives: Limited BRZ
Drives: 4Runner
That makes sense. Any chance you can get the size and we can look for a reasonably priced replacement option?
diirk
Site Moderator
Drives: Stuff
Even those should be crush washers. When you use one of the new ones you'll feel it crush. Honda's been using that style for a long time. They look like normal washers, until you use them the first time. I wonder if my old S2K ones would fit...
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
My point is when you reuse them at least the first time they seal and don't leak what so ever. I am all for changing out something if there is a benefit but if it doesn't leak than its working.
#10 | |
Site Moderator
Drives: Stuff
My point was simply that I highly doubt they are normal washers, despite their appearance.
-Dave
#11 | |
Drives: Limited BRZ
#12 |
#13 | |
Site Moderator
Drives: Stuff
![]() For this first change I re-used them even since I haven't gotten my replacements in yet.
-Dave
#14 |
Drives: BRZ Limited
So I just received my overpriced gaskets/washer for the transmission and the differential:
Differential fill plug gasket: SU00300122 - 24mm OD x 18mm ID x 2mm Crush Differential drain plug gasket: TOY1215710010 - 24mm OD x 18mm IDx 2mm Crush Transmission fill/drain plug gasket: SU00303626 - 24mm OD x 18mm ID x 2mm Flat They all look to be aluminum but that is just a guess. All measurements were made with calipers. Edit: The crush washers stuck to the magnet on the drain plug so I guess they are not aluminum Left Image is the diff drain/fill gaskets and they look identical. They are the exact same outer/inner diameter and thickness. They are both crush type washer. The right image is the transmission fill/drain plug gasket is the same size as the differential gasket but is a flat washer. After I pull the transmission gasket I will compare the thickness of the used and the new gasket to see if the transmission flat washer did actually "crush". Edit: The original flat washer was within a 1000th of an inch of the new flat washer so I would guess they are not meant to crush. When I order the differential crush washers again I will just order two of the same part number instead of two different parts. Last edited by developer; 12-04-2012 at 03:01 AM. Reason: Additional Info |
| Washer Mod? | 636 | Engine, Exhaust, Transmission | 64 | 02-20-2018 05:08 PM |
| Pressure Washer $60 at super store | Aznek | CANADA | 6 | 09-10-2012 12:08 PM |
| Engine oil drain plug washer | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-28-2012 12:28 PM |
| front washer? | Filipino Royale | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2012 03:06 PM |
| Man Crush A Friend's Car With A 100-ft Axe | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 01-19-2012 04:31 PM |
