#1 | |
AIM4APX
Drives: 2013 WRB BRZ Limited
BRZ jammed window issue/blinking auto light?
[ame="http://www.youtube.com/watch?v=OivSqN-IwSQ&list=UL"]BRZ window jammed - YouTube[/ame]
This morning is was about 21*F outside (rained 2 days ago and was 61*F) and when I opened my door the windows rolled down, as usual, but did not roll back up and then the 'auto' lights started flashing. They stayed flashing for my entire drive to work. I'm going to check them again at lunch time and I see some potential mention in the manual on page 72: Quote:
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Drives: Whiteout FR-S
The auto roll down tends to scare me at freezing temps. I haven't had an issue yet but there has been ice on my window and you can hear the ice cracking because of the auto roll. I can't imagine this is good for the motors.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
Drives: 2026 BRZ tS coming
Just happened to me. It's cold (-7 Celcius) and driver window seemed frozen and didn't want to go down. Both "Auto" light switch started flashing and window barely moves up or down (it's gladly kinda stuck in the closed position). Tried the owners manual "fix" listed above but no luck...
Any advice besides calling the dealer guys? |
#4 | |
Drives: 2013 Scion FR-S 6AT Firestor
On the FR-S anyway when I had it happen, I roll it down partway, and then roll it up and hold up until you hear a click, about a half second after it stops. Should reset it all. Please use search next time, I did a search for "window" in the issues section you posted in, and found these two very applicable threads: http://www.ft86club.com/forums/showt...ghlight=window http://www.ft86club.com/forums/showt...ghlight=window
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna 5AD Spoiler 205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only) Rally Armor mudflaps in black with red logos |
Drives: 2013 FR-S Hot Lava
Same issue here this morning. Damn it!
Live to drive another day
So, is there any way to just disable this feature?
Ultramarine 2013 Scion FR-S 6MT
Drives: GT86
Happens every cold morning here
I'll have to reset them everytime and it works again. I'll roll the windows all the way down, then all the way up and hold the button for 10 seconds and they reset.
Kouki-Monster
If you get a remote start installed and let the car / interior warm up a little before getting in, you will not have this issue nearly as often / at all.
it's been -13F to -22F and colder here lately .. when I run the car for a bit before getting in I haven't had any issues.
Rich Anderson
EMPOWER AUTO |
#9 | |
Drives: asphalt FR-S
#10 |
AIM4APX
I posted from my phone via tapatalk, and the search didn't pick anything up. I went to those other threads for a solution though. They are filled with all the info you will need. Fwiw, this has happened twice since this incident and the roll down and back up has worked both times.
#11 |
Drives: Accord 2007
The manual instructions make no sense to me...
My FR-S has been having this problem recently so I googled and ended up here. My driver's side control for the passenger side doesn't work, but the passenger's side power controls work fine. The passenger side (and driver's side) has been sliding down. I wonder if this will break one day? Anyway, good to know you can reset the blinking light. I will try that when I get back in my car. |
#12 |
Some guy in a white car
Drives: 2013 SWP BRZ Limited
just put the window down, then back up and hold the switch. its not really that complicated.
2013 Subaru BRZ Limited 6MT - Satin White Pearl![]() |
#13 |
Drives: RAVEN
Yes. There is a thread on it by one smarter than me. It is also quite simple.
Scion wont endorse it, so remember to disable the disable if and when you take the car in for warranty work on the windows. When I bought the car, I had to wonder how stupid a designer/engineer you had to be to integrate that feature into a car, but that was when I thought that failure meant you could not open the door.That this not the case, door opens fine in the full up position. Now that I have driven the car in winter and found out what happens when it stays down and you don't notice, I wonder how stupid a car company would have to be not to do any winter testing. You could never convince me that they did. |
#14 |
Drives: 2013 WRB BRZ Sport-Tech 6MT
What exactly is the point of the window rolling down and back up every time you open the door anyways?
| What is that blinking dash light when the car is off? | JayNutter | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-03-2014 11:59 AM |
| Small window door issue (rubber seal) | Subforever | Issues | Warranty | Recalls / TSB | 7 | 05-20-2013 06:32 AM |
| Teaking Tail light and Driver side passenger window auto down | feyrerm | Issues | Warranty | Recalls / TSB | 2 | 08-11-2012 01:32 AM |
| Issue with Simple Shut Window Feature | Jayp | Issues | Warranty | Recalls / TSB | 5 | 07-27-2012 12:18 AM |
| How to remove third brake light (to tint back window) | 96z2 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 06-07-2012 05:14 AM |
