Drives: FRS
Catch Can Debate
I have been wanting to install an oil catch can or oil separator on my FRS for sometime now. After lots of research and drawn out discourse, however, I am still not sure which unit is the best. Here are a few of the products in question and some comments on them. Perhaps we can begin a bit of a dialog on the subject in order to draw out some new information and expel some rumors regarding catch cans. Here we go.
The Crawford Performance AOS http://store.crawfordperformance.com/store/products/652 I like this unit. I think it has a great placement because it keeps the plumbing as short as possible. I also like that it addresses the intake line as well as the PCV line so it does the work of a dual can. THis is great for those looking to go forced induction. I, like many others, am still not sure sending the blow-by back into the engine is the best idea. I understand it may not be all THAT detrimental, but it seems to me if we can catch the stuff and dispose of it we might as well. I guess if you were too lazy to service a normal catch can this would be the way to go. But for the best performance... I am not so sure. Radium Catch Can https://radiumauto.com/index.php?p=p...id=28&parent=0 Interesting design. I have been told that many people pick this unit because it was "flow" tested to ensure proper integration with the vacuum/PCV system. I am curious if (a) this is true, and (b) if it really makes a difference. I really like the integrated dip stick. I also like the fact that the unit unscrews in the middle for emptying. At the same time these clever additions make me worried that they may start leaking down the line. I am definitely not a fan of the "baffling." They use small mesh screens like the ones out of your house hold faucet head. I am sure they work but there isn't much surface area there. Saikou Michi Catch Cans http://www.saikoumichi.com/ These are hand made and built to order. You can get them in any configuration you can imagine. They also offer single and duel units of various sizes to fit nearly any set-up you may need. They also seem to be a great value. For baffling he uses stainless mesh which I am unsure about. It has a good deal of surface area but I am not sure how it would effect the flow of pressure going through the can. It also drains from the very bottom which would make servicing an issue with most installations. The 42 Designs Catch Can http://store.42draftdesigns.com/Oil-...Cans_c_71.html I think this one may be my favorite at the moment. I particularly like the "stealth" model. The baffling seems very good to me. Lots of surface area to condense gas to liquid. The downside here is that if you plan to turbo or supercharge down the road you would most likely want a duel can and 42 designs doesn't make one. In that event, you would have to end up buying and mounting two (yielding the same protection as the Crawford unit). The Ultimate model has a dip stick which is nice for convenience but may start to leak down the road. I like that both these units drain on the front of the can making servicing much easier. The Cusco Catch Can Not to big of a fan of this one. No internal baffling. I am also not sure how to empty it. I do like the placement and the fact that it is car specific. I can't help but think it can't hold all that much liquid given its horizontal position. Thoughts? Questions? Comments? |
Drives: Whiteout FR-S
I'm surprised there aren't more application specific models, the Crawford is a tad overpriced imo and the Cusco doesn't seem to really do anything. I like the Saikou Michi one but i don't know the specifics to give him to get it built.
Drives: Silver FRS
interested to see where this thread goes..
I'm looking at doing the Radium dual catch can setup, but I am going FI so it's just a matter of safety than anything else. The Radium setup just oozes quality too, the D3 setup is also nice and I might be swayed to try it out, but I really like how the Radium is setup versus all the open loop systems.
Drives: '89 911, '06 GTI, '13 BRZ
Is a catch can even needed on a street car? My BRZ does not use any oil and I mean NO oil. The oil level at 5K miles on the oil was still right on the full mark dot.
That said what benefit would a catch can be?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
#6 | |
Drives: FRS
EVERYONE PLEASE: This is not a debate about the need for a catch can. This is a place to discuss the available catch cans and their designs. Threads have a way of going on tangents in this forum so lets try and keep things on track. |
I have the Crawford AOS and it rattles like a mofo. I'm not the only one with this issue. Crawford has yet to address it, so I'd go with another model if I had to do it over again.
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I run a Moroso: http://www.ft86club.com/forums/showthread.php?p=654722
Internal baffling, easy to drain, no rattles. This picture, posted by Crawford Performance is why I installed one on my BRZ. They pulled apart a low mile FRS to find oil on the pistons. The car was still N/A as far as I know, but it had apparently been run very hard, but it was still enough to warrant the small cost.
Drives: FRS
I also like the moroso unit. It looks very simple and effective. It seems a bit small though. How often do you have to empty it?
#10 |
Site Moderator
Drives: ichi 86 Project
Wasn't there an oil catch can that had hose that connected to oil cap? I thought, one member here had one of those. iirc it wasn't cheap, but it looked pretty cool
#11 | |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
#12 | |
Site Moderator
I'm going through the treads like crazy to find that pic! |
#13 |
Site Moderator
I've freaking found the pics I was talking bout
#14 |
Drives: Silver FRS
after reading this thread and searching the net for reviews and watching videos, i am now going to buy a catch can haha. thanks to the OP for posting this, probably going to go with the Radium. can't believe the amount of crap that thing catches.
| BRZ vs FRS - The Debate | TAP Auto Parts | Scion FR-S / Toyota 86 GT86 General Forum | 139 | 05-07-2013 07:26 PM |
| The Great Torque vs. Horsepower Debate | phenom86 | Engine, Exhaust, Transmission | 53 | 11-11-2012 10:54 PM |
| The Great Hatch vs Trunk Debate | nate89 | Scion FR-S / Toyota 86 GT86 General Forum | 229 | 10-24-2011 10:39 AM |
| Forget the NA vs Turbo debate!!!! | Midship Runabout | Engine, Exhaust, Transmission | 69 | 04-05-2011 06:24 PM |
