Drives: FRS
Installing the q300 myself
any thing special i might need to know or any good tips from the ft86 forum gods
Spray the hangers with silicone lube before removing them, makes removal easier. Only issue I had was tip alignment but eventually I got it. I think all u need is 12 and 14mm sockets and wrenches.
Version 2 Coming Soon...
Drives: Turbo Argento FRS, Asphalt FRS
^That.
Part Out Thread: http://www.ft86club.com/forums/showthread.php?t=39992
1337
Drives: 2013 BRZ WRB S/C
Don't tighten the bolts completely until you have everything installed. Just get them close and then allow for some wiggle room. Make sure the tips are where you want them (helps to have a friend holding them, and then torque everything to spec.
Penetrating oil spray might be necessary to help remove the old bolts but since the car is so new I doubt you will have much trouble. |
once you have it set, torque it all down SYMMETRICALLY
Drives: Asphalt AT
Don't ever look down.
Drives: FRS
thanks for all the good advicee
Drives: 2013 WRB 6MT BRZ Ltd.
Though it's already been mentioned, I want to emphasize that lubricating your hangers is really something you don't want to skip out on. When I did it myself, I was on jackstands in a cramped 1-car garage. A spray of WD-40 made the difference between me struggling with one damned hangar for 10+ minutes and debating whether I'd have to abandon doing it myself and get towed to a shop to something I could slip off easily with one hand.
Also, if it's your first time, don't believe any estimates on time. While I wasn't rushing and started at 1am while already quite tired, I probably quadrupled the amount of time it takes to install a headerback that other people who are using power tools and/or have done it before. The pride you feel afterwards is totally worth it though
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
when installing, start from the rear and work your way forward. It should help with keeping everything aligned.
#10 |
Drives: CBS BRZ
Also, a jack is not enough so make sure you use jackstands!
#11 |
Drives: FRS
i just got it !! so excited to install it to bad its already getting dark
#12 |
Drives: FRS
today is the day!
#13 |
Gluck man.
#14 |
The Silver Shnerfer
Drives: 2013 SWP BRZ 6MT
Does the cat-back alone throw any codes if its my 1st performance add on?
| Invidia Q300 vs. Perrin Catback (Non-resonated) | Taylor13 | Engine, Exhaust, Transmission | 26 | 02-06-2014 08:26 PM |
| New Invidia Q300 in stock and ready to ship! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 8 | 02-18-2013 09:07 PM |
| **BLACK FRIDAY!! Invidia Q300 FRS/BRZ 614.25 SHIPPED!! +10% off Special!** | RallySport Direct | Announcements, Contests, Giveaways | 0 | 11-23-2012 03:16 AM |
| Invidia Q300, Frontpipe & N1 Teaser Videos! | RallySport Direct | Engine, Exhaust, Transmission | 18 | 10-17-2012 05:00 PM |
