Old 12-19-2012, 04:15 PM   #1
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
TF Brake Duct Cooling Kit
Here is a quick sample of the prototype brake kit that's currently in development.
No clearance issues at full lock with suspension loaded.
You can see (....kinda) the 6061-T6 aluminum backing plate inside the brake rotor. forces cool air to pass through the rotor vents.
From the front view with wheels straight. You can see where we had to trim some of the fender lining for the hose to pass through.
view from under the car. See the NACA Duct.
We could barely notice the NACA duct was even there....
Hope you enjoyed....
Touge Factory is offline   Reply With Quote
Old 12-19-2012, 04:44 PM   #2
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Why not use the fog light areas? They seem perfect for something like this!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 12-19-2012, 05:00 PM   #3
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Finally... a back-plate. Keep us posted!
cobrabyte is offline   Reply With Quote
Old 12-19-2012, 05:08 PM   #4
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Hope there will be some type of compatibility with the BRZ bumpers!
spitz is offline   Reply With Quote
Old 12-19-2012, 06:18 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Interesting setup. Please keep updating for more info!
Old 12-19-2012, 07:10 PM   #6
Touge Factory
Drives: ZN6
1. It would increase the cost of the kit.
2. Location of our current NACA duct will have more direct air flow due to the shape of the bumper. Because the bumper is slanted and the opening size would be limited in the fog light hole, you wouldn't have the same air flow as the current design.
3. By creating more openings on the front of the bumper - you create more aerodynamic drag.
4. BRZ guys can use this kit too.
Yes, without a back-plate the cool air would just escape and never reach the rotors.
Yup, we want to make this kit simple and functional for both cars, without having to purchase model specific kits.
Old 01-12-2013, 12:46 AM   #7
fastfrs
Drives: frs
any more info on the dust sheild/backin plate of this kit?
fastfrs is offline   Reply With Quote
Old 01-12-2013, 04:12 AM   #8
Oh Damn Andrew
Oh Damn Andrew's Avatar
Drives: 2013 Whiteout FRS
Definitely interested in this! ETA on production and costs?
Oh Damn Andrew is offline   Reply With Quote
Old 01-14-2013, 05:22 PM   #9
Touge Factory
Drives: ZN6
The availability should be early february.
Retail price on this complete kit is: $399.00.
Old 01-14-2013, 05:47 PM   #10
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I want to see pictures of the back plate and drivers side. How are you routing it around the washer fluid tank?
post_break is offline   Reply With Quote
Old 01-14-2013, 05:52 PM   #11
Touge Factory
Drives: ZN6
Here is the prototype back plate.
Once everything is in place - we will have more detailed pics of the kit installed.
Old 01-14-2013, 06:00 PM   #12
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I like.
Seems properly engineered amd nicely packaged, looking forward to hearing how effective it is on the track at reducing temps.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-15-2013, 01:15 AM   #13
balance
Drives: 86 & Picanto
Nice Job, TF! I also like where this project is heading!
@TF,
Do you have any ideas as to whether this kit, once fully developed, will be compatible with JDM G & RC models that come with smaller front brake set-ups?
AFAIK, the front pads are interchangeable between the higher-spec (i.e., FR-S/BRZ) and lower spec cars while the rotor sizes are different.
Thanks in advance.
balance is offline   Reply With Quote
Old 01-15-2013, 01:21 AM   #14
RYU
RYU's Avatar
Drives: really slow...
I love that backing plate! It's so key! This should help me get more life out of my brakes and maybe even put off the expense of a BBK for a while longer.
I don't like your front intake solution though (no offense). I hope you can sell the kit w/o that piece because I want to use something like these guys have.
RYU is offline   Reply With Quote
FRS bumper duct VENOM~ Cosmetic Modification (Interior/Exterior/Lighting) 36 12-12-2015 01:15 PM
Arrows Japan Brake Duct Cooling Kit & Suspension BPAuto Brakes, Suspension, Chassis 65 06-22-2013 10:35 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 01:03 AM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 02:37 PM
