Old 12-22-2012, 04:39 PM   #1
S1000rr
Drives: Silver
Help installing AP front pipe...
I can't seem to figure out how to get this thing on the front has to be over the subframe then the front pipe slides in? Do you have to twist it to position correctly after???
S1000rr is offline   Reply With Quote
Old 12-22-2012, 05:23 PM   #2
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
try installing the overpipe from the front... twist and turn..
TyperRspec789 is offline   Reply With Quote
Old 12-23-2012, 03:05 AM   #3
S1000rr
Drives: Silver
Yea I was doing that. Little trial and error but got it on and the rest of the exhaust went on smooth. Damn this thing is loud.
Old 12-28-2012, 03:22 AM   #4
Bluecille
Drives: Scion FR-S Ultramarine
What type of system did you go with?
Bluecille is offline   Reply With Quote
Old 12-28-2012, 07:17 PM   #5
S1000rr
Drives: Silver
I went with the AP system. Header back.
Old 12-28-2012, 10:59 PM   #6
gmookher
to install an overpipe, you have to loosen the right side motor mount and jack up the motor a bit to get the overpipe in
to add a front pipe it should be cake
gmookher is offline   Reply With Quote
Old 12-28-2012, 11:10 PM   #7
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I've done two overpipes, perrins, and motivs, they spiral right in without ever having to jack up the motor.
post_break is offline   Reply With Quote
Motiv Concepts Front Pipe with cat JoeBoxer Engine, Exhaust, Transmission 68 08-06-2014 09:27 PM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 10:44 AM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 02:10 AM
