Drives: Ft86
WTB : Wheels & Rear trunk spoiler
Anyone know where can i buy TRD rear trunk spoiler MS342-18001-A0 in White [37J] and Work CR Kiwami Wheels 18 x 8.5 +38 front with 18 x 9.5 +38 in Dark Bronze [AHG]
Or if anyone wants to sell theirs? Thanks in advance |
Drives: 86GTS 6M
There was a couple of TRD spoilers pre-painted on ebay. I know StreetFX were selling one there. Otherwise check out importmonster, if they don't have one now, can get one no problems.
Drives: Solar Orange GTS Limited Edition
There's a white TRD spoiler for sale at gt86comau
Cheers Len |
#4 | |
Drives: Ft86
![]() & Merry c"mas guys |
Drives: Ae86, Jzx90, jzx110
Or try the guys over here in NZ at north shore Toyota.
Peter, Nick or Keegan. |
Drives: Mt Fuji Red 86 GT
Just as a tip - the 9.5in +38 WILL stick out at the back, so if you want to stay legal, maybe go a less aggressive offset. If you don't care about being legal, go for it
Drives: GTS 86 Galaxy Blue
I dropped mine 30 mm on the rear and it sat pretty good.
When I put the 9.5in +38 on the rear at stock height and camber they stuck out terribly. You will be surprised how much the camber changes in 30mm and how well the wheel tucks in. I correct mine with Cusco lower arms and the wheels sit ok. That is 1.5 degrees negative. |
Drives: 86
Running -1.5 degree at the rear and your wheels tucked in?
I'm running -2 and its not completely flushed. Most 9.5+38 that are flush on this forum are running -3 at the back.... |
Maybe the Pirellis are thinner than some other brands. 245/35 18
How much did you drop your height? |
#10 |
Nardi's are the ones I have seen that stick out. with his -2 camber it isn't too bad, but probably 6-8mm??
Tyres don't affect how much the WHEEL sticks out... If the wheel is outsie of the guard it is illegal. Doesn't matter if the tyres is under.. |
#11 | |
Drives: Ft86
![]() Thanks for the tips I thought it would look like |
#12 | ||
Drives: Ft86
May be i need Rear lower control arm ? Or i just need to low it more? |
#13 | |
Drives: Ft86
![]() Then what offset do you think its safe to run if i still wants to run staggered? May be 8.5 +45 (f) & 9.5 +45 (r) ?? |
#14 |
Drives: 86
My car has extra track from the factory then??!!?? I'm very lost.
Or maybe My wheels are +30 instead of +38...... 8.5+45 and 9.5+45 is very safe |
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 04:27 PM |
| WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk | R0ME0 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 01-07-2014 10:36 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Exterior Parts (Aero, Lighting, Etc.) | 1 | 12-30-2012 04:14 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Southern California | 0 | 12-16-2012 03:46 AM |
| WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk | No Limit Motorsport | Exterior Parts (Aero, Lighting, Etc.) | 5 | 10-03-2012 10:03 PM |
