Ontario's FT86
Drives: 2016 Lexus GS-F
Engine oil light briefly flashes after start up
Hi guys,
I'm not sure if I'm over sensitive or something but I realize my engine oil light will blank for a second right after I start the car and then it goes away almost immediately. I know it might be because the oil pressure needs to build up after sitting for a longer period of time, I'm just wondering if all FRS/BRZ are like this?
Drives: LS Swapped BRZ
100% normal operation :-)
Sarcastic SOB
I think you meant that you oil light will "blink", not "blank".
It might just be a normal thing as the sensors must need to receive some sort of blanking signal (correct microcontroller terminology) at start up to make sure nothing is stuck on. Take a look at another car to compare. I wouldnt worry unless it stays on a while, but it couldnt hurt to tell the dealer next oil change just in case.
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Sounds like fairly normal operation but just to be safe check your oil level (which should be done periodically anyways)
Nolan
Drives: 2014 Wrb Brz limited 6m
if your not using an OEM oil filter then the anti drain valve may be bad causing the oil pump to have to fill the oil filter first.
Drives: white-out FR-S
Anyone can chime in? I'm noticing this too.
Drives: 2014 BRZ MT (Sold); 2006 V70R
Necromancy.... read above posts, no need to revive.
'14 BRZ LTD MT DGM
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
| briefly battled a McLaren MP4-12C... briefly | PMok | FR-S / BRZ vs.... | 13 | 12-11-2012 01:24 PM |
| Will not rev over 4000rpm and engine light on. | 000 Racing | Engine, Exhaust, Transmission | 14 | 10-03-2012 08:36 AM |
| Check engine light? | czar07 | AUSTRALIA | 0 | 09-01-2012 03:50 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
