Old 01-02-2013, 07:09 PM   #1
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Lug Nuts - Geez
So I have a set of tires and wheels coming. Enkei PF01 in silver. Going on my Firestorm FRS.
Gonna show my age here but I'm used to buying a set of standard chrome acorn lug nuts and calling it good. The choices out there for the Scion are dizzying.
I'm thinking I want a set of black or red nuts and closed end. From there I am lost on length, style, design..... Can someone recommend a quality brand, secure, size, from there?
FRSFirestorm is offline   Reply With Quote
Old 01-02-2013, 07:14 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Gorilla has some black closed end one's you can get, if you want to spend more Muteki has red, black, etc closed end also. Make sure you get 12x1.25
JoeBoxer is offline   Reply With Quote
Old 01-02-2013, 07:15 PM   #3
Hanakuso
I just went with black Rays 17 Hex (steel) lugs. Little pricey for steel lug nuts but Rays usually make high quality stuff. Gorilla makes good and cheaper closed end lugs
Hanakuso is offline   Reply With Quote
Old 01-02-2013, 07:18 PM   #4
FRSFirestorm
Red is Fastest
Whats all the different drive styles about, splined, keyed, etc... Advantages or gimmicks?
Old 01-02-2013, 07:20 PM   #5
Hanakuso
Basically makes it harder to steal your wheels, although if someone really wants them it's still possible. Basically having lug nut locks is more time consuming to steal.
Just make sure you buy aftermarket specific lug nuts since OEM lugs won't perfectly mate up with aftermarket wheels. Also make sure it's the correct threading
Old 01-02-2013, 07:21 PM   #6
JoeBoxer
JoeBoxer's Avatar
Most tuner style nuts are splined but they all use the same key so they don't offer any protection without a lock.
Old 01-05-2013, 06:04 PM   #7
FRSFirestorm
Red is Fastest
Got my tire/wheel package from Tire Rack. It came with a set of nickle gorilla nuts. Same ones I ordered in black.
FS: Work Lug Nuts (Bronze) FRS2000 Wheels and Tires 3 11-07-2012 06:57 PM
Muteki Lug Nuts gms Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-05-2012 07:13 PM
Lug Nuts? Reflex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-21-2012 08:38 PM
Stock Lug Nuts?? ESC POD Northwest 8 10-15-2012 01:43 AM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 03:04 PM
