Old 01-10-2013, 02:00 AM   #1
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Powder Coated Wheels Safe for the Track?!?
I found a good deal locally on another set of 17x9 et42 wheels but they have been powder coated red. I know it will add a touch of weight but I'm just don't know much about the process. Would these wheels potentially be weakened by the coating process and unsafe for track use?
TIA!
Old 01-10-2013, 02:05 AM   #2
Fnbeast86
Drives: Firestorm red fr-s
If I'm thinking right powder coatig shouldn't hurt the wheel itself especially on a track
Fnbeast86 is offline   Reply With Quote
Old 01-10-2013, 04:11 AM   #3
simpleisbest
Senior Citizen
Drives: Scion FR-S
I've seen a powder coated wheel fail at autocross first hand. Looked nasty, but luckily no damage to the car nor driver. Was the wheel powder coated? Yes. Was it the direct cause of the failure? Not sure.
simpleisbest is offline   Reply With Quote
Old 01-10-2013, 04:20 AM   #4
Only if it was PC'd with a wheel-specific low temp process.
I never recommend aftermarket PC for anyone period when it comes to wheels. Reason being, a lot of PC places will say they offer the right process just to get the business, when they don't.
Old 01-10-2013, 09:50 AM   #5
Chicago
Drives: DD Lexus IS 350 / Track Car *Soon*
Agreed 100% Please don't take any chances at the track!
Chicago is offline   Reply With Quote
Old 01-10-2013, 11:02 AM   #6
xwd
I saw an SSR Comp that had been powder coated bend terribly at an autocross. Find out no did the powder coating and ask them about the process.
Old 01-10-2013, 09:06 PM   #7
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
SSRs are notoriously soft wheels. Just food for thought.
Personally I've never seen (at the good amount of track days I've been to) a powdercoated wheel fail. Not to say they never have or never will, but this is honestly the first thread on ANY forum I've seen regarding reservations about it.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-10-2013, 10:22 PM   #8
d1ck
Drives: Black 2013 FRS
I've heard of it before and the reason it happens is this:
When the wheel is manufactured it receives a heat treatment which gives the aluminium the desired hardness. This has to be done right, because if it is too hard the wheel will be too brittle and will crack easily. Too soft and it will bend easily.
Heat treatment is done by heating the wheel to a specified temperature and holding it there for a period of time, and then letting the wheel cool at a predetermined rate. (could be minutes or days) Then the wheel may also be heated to a much lower temp and held for an extended period to anneal the metal and relieve stresses within the metal.
When powdercoating the wheel will be cleaned, sprayed, and then baked in the oven at some temperature which will harden the powder. I'm sure you can understand how this might potentially undo any heat treatment done by the manufacturer. Don't bake your wheels kids!
d1ck is offline   Reply With Quote
Old 01-10-2013, 10:58 PM   #9
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
The temp is low. It doesn't cause issues. Don't believe the BS.
chadstyle is offline   Reply With Quote
Old 01-10-2013, 11:02 PM   #10
OrbitalEllipses
Drives: Attitude
Didn't COR not warranty a guys wheels because he fucked with the finish which MAY have messed up the structural integrity of the wheels (failed at the track)? IIRC they were hard anodized aftermarket or something by the owner.
Old 01-10-2013, 11:40 PM   #11
d1ck
While I can't remember enough from materials to argue this point, you're not really very convincing. Care to elaborate?
Old 01-11-2013, 08:12 AM   #12
chadstyle
chadstyle's Avatar
I didn't feel like spending a ton of time trying to "convince" anyone. Here's the deal...a great friend of mine runs a powder coating operation that his dad started a long time ago. He grew up in the business. They do sand rail chassis for the best builders in the country, have accounts with wheel manufacturers, and do government work for the US army and Navy. This place is impressive. I've powdercoated tons of parts with him over the years including many sets of wheels for myself and customers of mine and I've never had an issue due to the powder coating and he has been coating wheels forever with no problems at all. The process includes an electrostatic charge to get the powder to stick and then they are baked at a very low temperature for any metal or alloy and only for a short amount of time. 300-350 F for 30 minutes or so. Then they're allowed to cool back to ambient temperatures.
People above that have seen "powder coated" wheels fail at the track have probably seen tons of wheels without powder coating fail as well. The track is brutal. To blame the failure on the powder coating without any further facts or reasoning is pretty ridiculous.
Old 01-11-2013, 03:32 PM   #13
BlaineWasHere
Grip>Drift
Drives: FRS
Thanks for all the responses!
What I've gathered is not all processes and equal and if I don't know I should steer clear.
Old 01-11-2013, 03:42 PM   #14
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I would've thought the front wheels for sure would see high temps on a heavy car with good brakes.. My rims were way to hot to touch after a 20 min session at a track they say really isn't that hard on brakes.. SoW CW.. I never tested the temps of the rim.. But I thought they would've got as hot as a oven when being PC
Gixxersixxerman is offline   Reply With Quote
Minimal safe setup for a track day/hpde? slaxx Tracking / Autocross / HPDE / Drifting 37 01-19-2015 02:20 AM
Tell me again why you haven't Opti Coated your wheels.... 911fanatic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 12-10-2012 05:29 AM
So Cal powder coating Plxdjake89 Southern California 4 09-02-2012 05:30 PM
WHEELS THAT HAVE BEEN OPTI-COATED/GUARDED White64Goat Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-17-2012 12:10 AM
17x9 wheels came in - considering powder coating them Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-06-2012 12:01 PM
