Drives: 2013 Hot Lava FR-S
Wheel Directory: Axis X-Factor 18x8.5 +45
A couple of more pictures since I had a little let up of rain this morning before work. I'll still get some more if the Sun ever shines again.
86-75309
Drives: Toyota FR-S
are you lowered?
86-75309
Drives: Toyota FR-S
Ah ok, was asking cause im getting 8.5's all around and need to decide on 225/40/18 or 245/35/18 for my tires. Just afraid to go with 35's cause of bumps and what not :-/, Also that looks really nice on stock suspension, i dont mind that gap at all.
I don't see lowering the rear being any issue at all. The front is slightly more flush but I still don't think lowering an inch would be a problem.
I do notice the bigger wheel and thinner tire being slightly less forgiving than stock but I don't mind it. |
check out http://www.1010tires.com/tiresizecalculator.asp
245/35R18 is closer to stock diameter so your speedo will be a bit more accurate. Also, the difference in overall diameter between 225/40R18 and 245/35R18 is only about a quarter of an inch, so an eightth of an inch on each side of center. I don't see that making a huge difference in ride between the two. |
#8 | |
Drives: SSM BRZ
THANKS!! |
FRS Adept
Drives: Firestorm FRS
They look sweet. Contrast is nice. Axis rims are notoriously heavy though. You also appear to have added a heavier tire. Do you know the overall weight gain ?
#10 |
NW Region Moderator
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
#11 | |
I'm sure it's around 5 pounds total added per corner. The rims are 23.1lbs each. I knew that going in and was willing to accept it for the look I wanted. I've kept the stock wheels and will either use them or some lightweight forged wheels for autocross applications in the future with sticky tires mounted to them. |
#12 |
#13 |
Drives: SSM BRZ
#14 |
Updated with a few more pictures in original post.
| Wheel Directory: WedsSport TC105N 18x8.0 +42 | King Tut | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 39 | 12-20-2015 09:58 AM |
| Wheel Directory: TSW Interlagos 18x8.0 +35 | denkigrve | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 03-19-2014 04:01 PM |
| Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts | serial gixxer | Wheels and Tires | 41 | 03-29-2013 04:14 AM |
| FS: FL set of 18x8(45) RPF1 5x100 with tires | Scooby South | Wheels and Tires | 2 | 01-08-2013 11:35 AM |
| The Forester factor: an unexpected reason for limited BRZ / FR-S / 86 production | jruhi4 | BRZ First-Gen (2012+) — General Topics | 7 | 04-22-2012 10:37 AM |
