Pedals over Paddles.
Drives: Celica GT-S | 89 Supra | 07' Accent
A question regarding wheel/suspension aptitude.
I couldn't decide if this topic would fit well in the wheel section or the suspension section-- but i think it fits here.
I'm seeing a lot of people getting large wheels; sizes such as 17x9.5, 17x8.0 and so on. Even getting a wheel like the Enkei RPF1, the weight and price of wheels in this size can get up there. So, i'm assuming people are going for those size wheels to increase grip and to control oversteer. Now, my topic question is, instead of getting these large wheels, making them wider and wider, adding weight. . .could you not do a suspension/aero set up to make those large wheels less necessary? For instance, could you not just add a GT Wing and adjust the rear toe to Toe Inward 0.5 degrees, leave the rear sway bar alone or remove it, while stiffening up the front a bit? I would think that setup would control your oversteer enough to be able to benefit from smaller lighter (and cheaper) wheels. Am i wrong in this? - - - My history has been with small FWDs and trying to fit the smallest possible wheel over the caliper (typically 15'') and only going for a 205/50/15 tire, as to keep the overall weight of the wheel/tire at around 33lbs. Not to mention the effect smaller wheels have on acceleration and top speed.
![]() 2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily |
Drives: 2013 FRS Asphalt
People are adding large wheels and so on because they do help grip. And we race in classes that have rules. Not all the classes allow aero mods or large gt wings. So we do what we can with the money we have and the rules set forth. Some track the car some autocross the car and each has different needs.
2013 Scion FR-S AT Picked up 5/30/2012
#3 | |
However, as it's burning my curiosity, could you also comment on the validity of my logic behind my alternative to larger wheels, objectively?
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
It depends on what you are trying to accomplish. Adding negative rear toe and a big wing adds drag, more drag than a bigger tire patch would, so this is something to weigh the cost/benefits. Aero also has substantially less impact (some would lobby none) at lower/autocross speeds. Adding rear toe will also increase the wear on the tires.
Wider tires/wheels coupled with stickier compounds is the easiest way to increase grip with minimal sacrifices... steering feel and turn-in being 2 of the bigger sacrifices when increasing tire width.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#5 | |
Thank you very much for painting an objectively sound picture. I appreciate it.
#6 | |
One could argue that oversteer with this car is a setup or driving error, and using an alignment and aero to bandaid that doesn't eliminate the source of the oversteer. |
Site Moderator
Drives: Stuff
Or preference. I like a little oversteer in my cars.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
I've noticed all the really fast FWD guys that are local to me are a bit nutty and have their cars set up loose...
![]() They also run suspensions that are worth more than the cars themselves... ![]() I suppose the nuts behind the steering wheels may have a screw or two loose...
Detroit Region, MI
I'll also point out that based on the information provided in one of the early marketing videos put out by Subaru, they specifically mentioned that the wheel/tire package was one of the places they sacrificed on to keep the vehicle cost down with the assumption that owners would be replacing them.
I'd suggest based on this info and the other usage of the primacy tires, the OE wheel/tire package was specifically aimed at maximizing the EPA economy label.
#10 | |
Detroit Region, MI
#11 |
Detroit Region, MI
Also to address your questions RE wheel size... smaller overall tire diameter changes the drive ratio at the wheels, meaning you will be at higher RPM in the same gear going the same speed (I know, this is a 'duh' statement, but stick with me here)... in older econobox FWD cars, close ratioed gear boxes were not common, they had wide ratios and typically 4 or 5 speed transmissions, so when you reduce the tire OD, your gear box can still reach a decent top speed in the same gear. drastically changing this ratio on a close ratio gearbox will get you in trouble with being between gears too much, so you hardly ever see that practice anymore unless someone has changed their trans or diff gear ratios as well.
#12 |
Because compromise ®
Drives: Red Herring
#13 |
Detroit Region, MI
It's due to the way the tire responds to a change in heading as it is rotating. The tire flexes creating a difference in inner and outer sidewall speeds (the sidewall which is running the shorter radius is turning at a slower RPM than the outer sidewall and the tire patch becomes more teardrop shaped. As the tire rotates it creates a pneumatic trail, with larger tires, there is more deformation, which translates to a "numb" steering feel and a less responsive turn in, assuming you don't exceed the potential grip of the smaller tire and all other variables are constant (sidewall stiffness, no discernible difference in tire pressures, temperatures, etc...) the narrower tire will feel sharper. This also works in opposite effect as the wider tire will also not auto-center as well. Driving with the wider tire is just something you have to adjust to, it means you turn in a hair earlier, a hair faster, a hair further, and reduce the steering input a a hair sooner as the bigger tire catches up and reaches steady state.
Edit: my image link wasnt working so I removed it.
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ Last edited by Sccabrz192; 01-10-2013 at 04:47 PM. Reason: Image link broken |
#14 |
Drives: Red Herring
Thank you for your detailed reply.
| Suspension/Wheel budget of $5000-6000. Priority is actual upgrade, looks are 2ndary | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 09-16-2012 04:46 AM |
| suspension question | Bruninho8 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 08-14-2012 06:03 PM |
| Wheel fitment question | thelegaCy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-06-2012 12:22 AM |
| Stock Suspension and Wheel Fitment | bneale | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 06-29-2012 08:42 PM |
| BRZ vs. FRS suspension question | smbrm | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-12-2012 10:55 AM |
