Old 12-02-2011, 10:42 PM   #1
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Intake resonance pipe?
So will this take away from the performance of the car at all? Will a delete help the exhaust flow better? I have never had a car with a intake resonance pipe. Just curious how useful it is and if a delete would be beneficial.
tranzformer is offline   Reply With Quote
Old 12-02-2011, 10:43 PM   #2
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
I am interested as well but I would assume many aftermarket intakes would not have the cut out for it.
KaliKev is offline   Reply With Quote
Old 12-02-2011, 10:45 PM   #3
pingpongitore
Drives: It Drives
An intake resonance pipe simply transmit sound from the engine bay into the cabin. It allows no airflow and attaches to the intake externally
It doesn't affect performance negatively or positively. It is just a work around to get more engine noise into the cabin without compromising nvh engineering
pingpongitore is offline   Reply With Quote
Old 12-02-2011, 11:00 PM   #4
tranzformer
Drives: Zoom Zoom
Ok that's what I wanted to know. I knew it wouldn't add to performance, just wasn't sure if it was taking away or not.
Old 12-02-2011, 11:04 PM   #5
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
There will be a trade off when going with an aftermarket intake with an increase of engine noise. If you don't mind it then you should be good.
Acoustic resonance:
Sounds are waves in the air, specifically longitudinal waves. These type of waves cause pressure waves (90 degrees out of phase with wave itself) that are directly proportional in strength to the amplitude of the sound wave.
It is possible to utilize this effect to increase intake air pressures within the intake tube. In most instances the amplitude of a sound wave is not that large. During resonance however the sound wave amplitude becomes much larger (and so does the pressure wave following it). During this resonance it is possible to gain significant amounts of torque and actually create positive manifold pressure (above 1 atm). This effect is sometimes called the AEM HUMP, where power spikes ~10hp for a couple hundred RPM around 4500 RPM in their cold air intakes. The resonance frequency
of a pipe depends on the length and the diameter of the tube.
Fn= n (v/4L)
n = wave number, v = velocity of sound (~340m/s), L length of pipe
Note: v the speed of sound changes with temperature.
The diameter of a pipe has a small effect on the resonance frequency as well. The sound wave behavior remains consistent
with that of a pipe for ~.6 times the diameter (D). So
Fn= n (v)
___________
4(L+.6(D))
For a 1-meter intake pipe this translates into a resonance frequency of 85 hz or 5100 RPM. The intake pipe reaches
resonance frequency when the driving force of the system (the engine) is also at that frequency. This is RPM/60;
rotations per second.
http://ftlracing.com/tech/engine/intake.html
Old 12-03-2011, 12:03 AM   #6
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
The new stangs got it as well
its gonna sound mean (I hope) with breathing mods
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 12-03-2011, 12:09 AM   #7
Longhorn248
Hook 'em
Longhorn248's Avatar
Thanks RRnold for droppin some knowledge. So basically a little bit more noise is the trade off for a bit more power from an aftermarket intake?
Longhorn248 is offline   Reply With Quote
Old 12-03-2011, 12:28 AM   #8
tranzformer
Drives: Zoom Zoom
Thanks RRnold.
Old 12-03-2011, 01:01 AM   #9
Dark
Elite Padawan
Dark's Avatar
Get tuned exhaust, it will be loud enough to get in the cabin. Tuned exhaust will probably be lighter, and have more power too.
Dark
Dark is offline   Reply With Quote
Old 12-03-2011, 01:05 AM   #10
tranzformer
Drives: Zoom Zoom
Eventually I would want a Ti exhaust.
Old 12-03-2011, 07:33 AM   #11
Levi
Drives: Toyota
I think taking away resonance pipe would also clean up the engine bay. There'll be more space for....a supercharger?
I don't what is the use of that. On a V10 like the LF-A or yes, but not on a 25K entry sportscar. I would rather prefere carbon fiber intake, like the M3 CSL E46 or even 320si E90. Those sound good.
Levi is offline   Reply With Quote
Old 12-03-2011, 09:52 AM   #12
torquemada
natural born kraut
Drives: EDM WRX STI MY06 WRB
ok, I hate it. It feels wrong, if you want sound, buy an aftermarket exhaust, thatīs pure and evil. I donīt care if VW does this with the GTI, or Porsche with the 911.
that generates sound
torquemada is offline   Reply With Quote
Old 12-03-2011, 12:19 PM   #13
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
The exhaust is what generates sound the intake resonance pipe just redirects the sound
Out of the FRS game
Old 12-03-2011, 05:42 PM   #14
ahausheer
Re-member
Drives: Toyota camry
Intake resonance pipes use a diaphragm that transmits only sound waves. No air is diverted from the intake path so performance should not be hurt. One thing you can play with is removing the intake resonator (black box adjacent to air filter housing passenger side) to see how it changes the sound.
ahausheer is offline   Reply With Quote
