Old 01-12-2013, 07:13 PM   #1
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Need Advice: Broken strut mount stud...
I was installing my new Hotchkis front suspension crossmember and have twisted-off one of these studs that the crossmember bolts up to.
Before you say it... I was using a torque wrench set at 14ft/lb.
In any case, how do you figure I can fix this? Not sure what kind of shop to take this one to. The stud broke but not before twisting out of its seat. There's no way to get another bolt into there from underneath so it's going to involve cutting/welding (I would guess).
Other than this, the crossmember bar is nice. Firm even though I'm missing one connection point.
Any help is appreciated!
cobrabyte is offline   Reply With Quote
Old 01-12-2013, 09:33 PM   #2
whataboutbob
AutoX-10/10ths every run
Rough directions/suggestion:
Remove the brace. Get a high quality drill bit that is about 1/2 the size of the original shank. Drill a hole with the drill bit in the center of the broken bolt. Get an easyout bit to fit the drill bit. Use the easyout to remove.
http://en.wikipedia.org/wiki/Screw_extractor
If in doubt, pay a professional for help. Good luck.
Build thread:Here
Old 01-13-2013, 08:50 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Every strut mount I've seen has these pushed in. I wouldn't trust anything but a replacement. Sorry man.
Could you take some more pics of the bar though?
Old 01-13-2013, 10:59 AM   #4
cobrabyte
cobrabyte's Avatar
Yeah, you can tell these were pushed-in, as well. I guess the good thing is that I pulled out most of the backing plate when this happened. I'll take it to the Scion shop to see what they suggest.
Thanks for the help, guys!
Old 01-13-2013, 11:17 AM   #5
Calum
That Guy
Might be time for some whiteline com-c top hats.
Old 01-13-2013, 12:16 PM   #6
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Yeah you're going to have to take, it apart push that one out and push a new one back in an easy out kit only works if it was screwed in not pressed in.
Sent from my SGH-T989 using Tapatalk 2
Old 01-13-2013, 01:18 PM   #7
whataboutbob
I didn't think about this properly when I made my earlier post. The easy out is the right answer for stuff that is screwed in, but not pressed. I vote COMCs!
Build thread:Here
Old 01-13-2013, 02:06 PM   #8
White64Goat
After going out and looking at mine, what you sheared off was one of the strut tower brace to firewall studs, not one of the front strut bolts. Since you busted off the one that is closest to the tower and the bracket is welded to the tower, I'm not certain you can even get that broken one out as it feels like the flat part on the underside is possibly captured by the welded bracket?? Maybe a small mirror and flashlight will give you a better look at it.
Old 01-13-2013, 02:09 PM   #9
#87
I usually post drunk
#87's Avatar
Isn't that just the top mount? I imagine it probably cost more in labor to replace than the actual part, so DIY time
#87 is offline   Reply With Quote
Old 01-13-2013, 02:35 PM   #10
Accurate Race Shop
Drives: Scion FR-S
Oh yeah the strut has to come off the spring removed the bolt pressed out then that whole process in reverse to put it back together. Going to take an afternoon so cue the music crack a beer and get to work.
Old 01-13-2013, 03:56 PM   #11
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
No worries. You will be the first of many of the twins to do this. These studs only require just past hand tight. If you are using a torque wrench(which I don't reccomend) - set it lower than 12lb ft. Really you can put these on with a 1/4" or 3/8 ratchet just past snug.
This was/is a common occurence forever now with the Impreza guys/gals.
Beyer Subaru is offline   Reply With Quote
Old 01-13-2013, 06:01 PM   #12
Calum
That Guy
After a second look, I agree with Mr. Goat.
Old 01-14-2013, 12:47 PM   #13
cobrabyte
cobrabyte's Avatar
Thanks for the thoughts/suggestions, guys. I'll need to take a better look at what I'm up against and plan accordingly.
Old 04-07-2013, 05:35 PM   #14
jesperswe
Drives: GT86
Happend to me today also, i broke off a stud but not to the crossmember, but for the strut itself. I will have to remove the whole strut and knock that stud out and insert a new one.
As for now i'm driving around carfully with just 2 out of 3 bolts attached to the strut
And of course you cannot buy the stud alone @TOYOTA. You have to buy the whole topmount
jesperswe is offline   Reply With Quote
broken, hotchkis, repair, stud, suspension
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 09:20 PM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
First brz broken into...sigh zex CANADA 74 08-04-2012 06:17 PM
