Old 01-15-2013, 01:44 AM   #1
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Water pump reliability - track use
Many of the German cars (along with other mfr coutries) now days use composite (plastic) water impellers. When I was buying my FRS, I asked the dealer if the impeller was composite or cast metal (Stl or Al). Only thing they could answer was that Subaru had not made any water pumps with composite impellers, but could not say, "FRS" has cast metal impeller.
So my question is, for those hard core trackers, are you running the original water pump, or after market?
Any other misc moving parts that you are replacing with aftermarket? Any plastic moving parts in FRS I should know about...?
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 01-15-2013, 03:09 PM   #2
G Speed
Drives: Cobalt
I don't think this is a problem with the car.. the plastic impeller was a big problem on the e36m3's
G Speed is offline   Reply With Quote
Old 01-15-2013, 03:18 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not even sure if there is an aftermarket water pump available and I'm fairly confident that no one has replaced theirs yet..
Can't answer the question on materials unfortunately.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-15-2013, 05:41 PM   #4
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Well, the dealer made calls to Subaru USA and could get a definitive answer when I was buying it either. I'm hoping some one has dissected it. Parts people didn't know either!
A $5 plastic impeller once cost me over $10,000 replacing a blown engine, which took place after the impeller broke and froze the engine within 5 seconds. Just heard a slight click, the next thing I knew, less than 5 seconds from the clicking, the engine was blown. If these engine runs hot, as did my other car, the impeller would be my biggest worry.
I think only GT3's still run cast impeller of the entire Porsche line up, as well as all Audi's and possibly all BMW's. most of the after market pumps have non-composite impellers.
Old 01-15-2013, 05:48 PM   #5
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Ask Crawford, he's had his engine all apart.
Personally I've never seen a plastic impeller on a Subaru water pump...but haven't taken the FA apart myself.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 01-15-2013, 05:52 PM   #6
gmookher
any e36 I buy or recommend gets a stewarts all metal waterpump, tho there is nothing at all wrong with the newer plastic pumps in use today. I just replace it every 60-80k miles as good measure on cars that have plastic.
gmookher is offline   Reply With Quote
Old 01-15-2013, 06:18 PM   #7
johhnc479
Drives: White FRS, 2011 Cayman, 1986 944
Maybe I'm wrong, but I've always thought of the plastic issue as being an age related item and less of a track thing. Perhaps heat and age together make it "really" bad. I think everything plastic (i.e. half the car) on my E36 broke evenutally.
johhnc479 is offline   Reply With Quote
Old 01-15-2013, 07:13 PM   #8
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Car had less than 60,000 miles on it.
Found out later, some owners in another state were thinking of class action suit, since even the OEM replacement was made of plastic. Apparently I wasn't the only one!
After the fact, my race specialist mechanic said, yeh we have to change that part!!!??? You think...?
Even my motorcycles don't have plastic impellers!
Old 01-15-2013, 07:23 PM   #9
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
my toyota 2zz had a oem plastic pump, swapped it out with the newer p/n which was metal. im going to guess its a metal finned pump.
Jesse is offline   Reply With Quote
Old 01-15-2013, 08:26 PM   #10
johhnc479
How old was the car? Pretty sure plenty of BMW's have broken water pumps before 60K.
Old 01-15-2013, 09:05 PM   #11
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Wasn't a beemer. Don't remember if it was the original one or one that was replace by the dealer during schedule maintenance
Old 01-15-2013, 09:07 PM   #12
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
So back to the topic. FRS ,,,plastic or metal?
Old 01-15-2013, 09:20 PM   #13
xwd
Like Opie said, Subaru has never used a plastic water pump an any modern engine, I don't see them starting on the FA20. It's not one of the parts people replace on the EJ series engines. People do replace the oil pumps with modified ones to maintain higher oil pressure, but that's a different story.
Old 01-20-2013, 11:30 AM   #14
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Like someone mentioned already, contact Crawford. They probably could tell you.
industrial is offline   Reply With Quote
Scion top rated for reliability FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 10-29-2012 05:13 PM
24 Hour Endurance Race Reliability Wes B. Engine, Exhaust, Transmission 30 09-14-2012 01:50 PM
Subaru Engine reliability? FRSCoupe Scion FR-S / Toyota 86 GT86 General Forum 24 06-07-2012 05:11 AM
Audi Reliability (and slew of other questions) Buggy51 Other Vehicles & General Automotive Discussions 8 11-10-2011 11:10 AM
