Drives: 2013 FRS Whiteout
Wheel Guys Chime In! Need advice on tire sizing
I'm hoping some of you that have been mounting multiple sets of wheels and tires can steer me in the right direction.
18x9.5 rear 18x8.5 front 1" drop on eibach pro kit I know I want to run 255/35/18 in the rear, I've heard that wil fit fine (correct me if I'm wrong), what front size will fit without any camber adjustment or fender modification. I'm not looking for the stretched look, I just want a tire that will fit without modification. Thanks on advance for any help it advice! |
wheel gap
Drives: whiteout frs, 04 xrs
do you know the offset of the wheels?
Yea sorry, 35 front 30 rear
Drives: Attitude
235/40/17 front sounds about right.
KCCO From Canada
Drives: Asphalt FRS
245/35 or slightly stretch a 225/40. i think the 225 is as tall as the 255 if I'm not mistaken.
Drives: Attitude
I did 225/40 with a 45 offset 8.5 in the front and 255/35 with 45 offset 9.5 in the rear. Did an alignment check all was good and no rubbing.
I think with you dropping it and inch you still be ok. You might do 35 front / 40 rear? |
Thanks for the input guys, my main concern is that it fits without modification and that it doesn't look weird.
Here's some comparison specs: Stock Tires Section Width: 8.46 in 215 mm Diameter: 24.61 in 625.09 mm 235/40/18 <------- Hard to match the rears with good tires Section Width: 9.25 in 235 mm Diameter: 24.47 in 621.53 mm 225/40/18 <-----This seems like it may look stretched or too different from rear Section Width: 8.85 in 225 mm Diameter: 25.08 in 637.03 mm 245/35/18 <-----This seems ideal but there's limited tire selectiion Section Width: 9.64 in 245 mm Diameter: 24.75 in 628.65 mm |
#10 | |
SLO NO MO
I think 245/35-18's would be the closest match if you're trying to maintain a diameter as close to stock as possible. Here are the tires I'm seeing as available in that size: BFGoodrich g-Force T/A KDW NT Bridgestone Potenza RE050A Run Flat Bridgestone Potenza RE760 Sport Bridgestone Potenza S-04 Pole Position Continental ExtremeContact DW Falken FK-452 Hankook Ventus V12 Evo (K110) Kumho Ecsta XS (KU36) Michelin Pilot Sport PS2 Pirelli P-Zero Pirelli P-Zero Corsa System Pirelli P-Zero Rosso Pirelli P-Zero Run Flat Pirelli Winter 240 Sottozero Pirelli Winter 240 Sottozero Serie II - R.F. Toyo Proxes T1 Sport Yokohama ADVAN Sport Yokohama S.Drive |
#11 | |
86-75309
Drives: Toyota FR-S
#12 |
@Foobar: You're right: 235/40/17 is Overall Diameter: 25.40 in 645.16 mm
Where as 245/35/18 is Overall Diameter: 24.75 in 628.65 mm I'm really having tough time picking tires, I know tires very well, but I am very hesitant when it comes to the special circumstance of this car and what I want to use it for. @Got3n I've been a Michelin/BFG dealer for 4 years, I would never get PS2s. I have been leaning toward Pilot Super Sports, but I have been considering G Force TAs as well. The car is not going to see much rain or snow, but I do want something that will stick once I go turbo and make a couple of 1/4 mile passes. |
#13 |
KCCO From Canada
Drives: Asphalt FRS
225 should be about the same amount of stretch on an 8.5 as the 255 would have on a 9.5 it should look quite similar IMHO
| Tire size advice | Lost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 11-28-2016 07:42 PM |
| Need advice on tire size for track duty?? | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 02-05-2013 08:50 PM |
| WTB: 1 OEM wheel with or without tire | #87 | Wheels and Tires | 11 | 01-31-2013 02:21 AM |
| New Sub System.. What do you guys think? Advice? | Sinthra | Electronics | Audio | NAV | Infotainment | 12 | 12-20-2012 03:16 PM |
| Plus 0 tire sizing | Brzer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 01-30-2012 09:15 PM |
