Old 01-16-2013, 01:19 AM   #1
NickFRS
Drives: 2013 Asphalt FRS
Anyone replace rotors yet?
I went to replace my rotors with DBA T3 fronts and stop tech rears but I ran into a problem.... After I put in my HAWK HPS pads I noticed the bolts that hold the piece where the pads are inserted were on really tight... I even split open my finger trying to take them off. (Hit my finger with a rubber mallet while holding the wrench) Ouch . Anyway I don't have a beaker bar.... any suggestions!? I want these acts of god... aka rotors... on my car!!! :happy0180:
P.s I've dont rotor swaps on my STi's before and they were not this tight......
NickFRS is offline   Reply With Quote
Old 01-16-2013, 10:50 AM   #2
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I didn't have any real issues. Righty-tighty, lefty-loosy. You are looking at the bolt, so make sure to visualize it properly (backwards).
I usually put a box wrench on the bracket bolts (17mm?) and hit it with a hammer (all metal hammer, not a rubber mallet). I actually use the right angle between the head of the hammer and the handle (less force, and no misses) - thus the reason for a metal handle, fiberglass or wood are going to get messed up.
A half inch drive ratchet should be good enough, just hit it with the palm of your hand. Padded gloves are suggested.
celica73 is offline   Reply With Quote
Old 01-16-2013, 11:12 AM   #3
ziggz501
ziggz501's Avatar
keep in mind you can use a hollow tube as a breaker bar. you don't necessarily have to buy a nice 24" breaker bar. just go to your local hardware store and get a hollow steel tube (shortened fence post would work) and put it over you ratchet for the extra torque that you need.
ziggz501 is offline   Reply With Quote
Old 01-16-2013, 11:38 AM   #4
Squishy
Drives: 2013 WRB BRZ
Get a breaker bar (air tools work too) - the bar is cheaper than the aggravation and busted fingers and it really isn't that much (I got a 36" breaker bar for $25 at Northern Tools (harbor freight would be similar Chinese made stuff anyways).
Squishy is offline   Reply With Quote
Old 01-16-2013, 11:59 AM   #5
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Harbor Freight will sell you a breaker bar for about $10. Well worth it. Works great for removing the wheel locks too. My impact gun had trouble with the wheel locks.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 01-16-2013, 03:13 PM   #6
NickFRS
Hmmm might hit up Harbor freight. Might also try metal on metal but I love my nice clean new looking tools..... But o well if it has to happen it has to happen. Weirdest thing is I tried my air tools and they maxed out and didn't work. Nice to have some insight thanks everyone.
Old 01-16-2013, 03:34 PM   #7
Should be easy if you use a 1/2" drive ratchet + socket + mallet.
I've done it for a lot of people at the track already; 1 good whack per bolt and it'll be loose.
Old 01-16-2013, 03:38 PM   #8
OrbitalEllipses
Drives: Attitude
Cheater pipe. Slip it on over the breaker bar to basically get a longer breaker bar that allows you to put more torque on the bolt.
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 06:54 PM
Looking to replace my sedan carbonBLUE Other Vehicles & General Automotive Discussions 5 01-11-2013 09:41 PM
Which ones do you like to replace the stock rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-11-2012 10:53 PM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 03:57 PM
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 08:52 PM
