Old 01-16-2013, 08:41 AM   #1
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
Trim removal DIY (Request)
Hi everyone! I am searching for th DIY for this so I can do a CF vinyl wrap but can't seem to find it, can anyone point me in the right direction? thanks! BTW I found one but it didn't have how to remove the round air ducts. Thanks again!
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 01-16-2013, 09:19 AM   #2
PrDarkKnight
Drives: Scion FR-S
BUMP!!
[SIGPIC][/SIGPIC]
Old 01-16-2013, 10:36 AM   #3
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i need a quick picture of the vent bezel removal as well. Just ordered the black ones. I feel like you could take a pair of pliers and gently pull at it but i don't want to break anything or scratch the surrounding panels.
abutterman is offline   Reply With Quote
Old 01-16-2013, 10:39 AM   #4
PrDarkKnight
Drives: Scion FR-S
same here! they felt removable, but didn't want to risk it
[SIGPIC][/SIGPIC]
Old 01-16-2013, 11:09 AM   #5
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
It would be great if someone could show how to safely remove the door handle trims too!
i_4got is offline   Reply With Quote
Old 01-16-2013, 11:25 AM   #6
abutterman
abutterman's Avatar
I saw the door handles in another thread, i think from a speaker swap or something. You need to use something that won't crack to easy as it's clipped in real tight but just start at the bottom by the fake leather trim and pull up hard. It takes some force but it'll come out. just be sure NOT to start at the top. The top clip doesn't go straight in like the rest. It's angled upwards and will break if you try to pry from there.
Old 01-16-2013, 11:26 AM   #7
abutterman
abutterman's Avatar
also be sure to just pry up the silver piece. The black grip around it is screwed down under the silver part.
Old 01-16-2013, 11:39 AM   #8
i_4got
i_4got's Avatar
Actually, do you happen to know how to remove the black part of the door handle? I'm thinking of plastidipping or wrapping it red to look like the GT86. I kinda want to keep the silver part on the door handle.
Old 01-16-2013, 11:43 AM   #9
abutterman
abutterman's Avatar
I haven't tried yet but i know there's 2 screws under the silver. Not sure if those screws release the grip or if there's more screws behind it or something. I know Nigel JDM sells the red grips from japan so they definitely come off but they're $150 for those. I wonder how well plastidip will stick to the rubbery texture. Worth a try though i suppose
Old 01-16-2013, 12:00 PM   #10
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
never tried plastidipping. is that hard to do?
Huehuecoyotl is offline   Reply With Quote
Old 01-16-2013, 12:08 PM   #11
i_4got
i_4got's Avatar
Plastidipping is pretty much the same process as spray painting, except you can choose to rip it off after it dries.
Old 01-16-2013, 06:05 PM   #12
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
https://www.dipyourcar.com/ lots of info and how to videos there.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 01-16-2013, 06:37 PM   #13
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I can take a video of removing the shift surround, headunit surround, and the plastic piece in front of the passenger seat if you need it.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 01-16-2013, 06:38 PM   #14
Skorov
Skorov's Avatar
Drives: 86 GTS White
@i_4got: I happen to take some snaps when I removed my handle trim. Here's a quick walkthrough...
Here's a photo of the back of the trim piece. There are some larger clips at the bottom, some small clips up the middle and a slit at the top.
Here's a photo of the handle with the trim off. I've circled some clips.
I think the easiest way to go is to start from the bottom (where it's pictured above). Once the bottom few flips are loose, you can just use your hands and pull the piece off. The slit slides out last.
I noticed this metal clip thing that remained on the door for me. Not sure of it's purpose, but thought I'd point it out anyway.
Skorov is offline   Reply With Quote
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 02:19 AM
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 08:47 AM
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 12:55 PM
Silver interior trim removal for plasti-dipping ph0en1xtk Cosmetic Modification (Interior/Exterior/Lighting) 1 10-06-2012 10:54 AM
WTT: BRZ(mine) trim pieces for FRS(yours) trim pieces Flat Black VW Interior Parts (Incl. Lighting) 14 07-27-2012 11:01 PM
