Old 01-19-2013, 01:09 PM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Is my Cusco catch can correctly installed?
Have asked this before but it somehow got buried.
The instructions provided were Japanese and only showed an install for the front crankcase vent. It is my understanding the PCV is the main vent for crankcase blowby and for a daily driver with spirited use this is the one to vent, if any.
So, I split the provided tubing into 2 pieces. One end goes from the PCV to the can. The other from the can to the regular entrance to the intalke manifold that the PCV was piped to.
The tubing diameter was way too big for the PCV outlet barb so I improvised. I removed the bark tube apparatus previously. Turns out the interchangeable "noisemaker" is a perfect adaptor for the pipe to the PCV. I removed the foam and crap inside the grey elbow on the bark tube and used it to hook the tube to the PCV. I will keep an eye on the plastic to see if it can withstand the heat exposure but so far so good.
I havent found a non-hack part to adapt tube to PCV but would appreciate suggestions.
People with real knowledge please confirm that the hookup is OK. I have also heard it should just vent to atmosphere for the can to be effective vs under vacuum. Then Id need to plug the PCV to manifold inlet. What if I stuff a bunch of steel wool through a barb inlet of the bottle to help catch suspended blowby?
Old 01-19-2013, 10:51 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
ok, where the PCV runs to the intake near the TB ... you unplug that hose and use the adapter (plastic tube) to adapt the hose to the new Cusco hose. That line will run into the side of the catch can on the drivers side of the engine bay.
you then use the plug supplied to block the now present hole.
the hose on the other side of the catch can you can run down to wherever and run it as atmospheric.
easy.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 01-20-2013, 12:16 AM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
Thank you for the input. I actually used the supplied plug for the growl tube hole in the firewall. Please bear with me here...does the system work under vacuum as I have set it? Not too keen about venting this to the atmosphere. I thought venting it was optional.
Also discarded the rubber molded PCV hose as it seemed like a long and clumsy way to route the gas.
Old 01-20-2013, 01:00 AM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
can you get a picture?
A catchcan should be sealed for your application and really should be an air/oil separator. The only place it should be hooked up to is in the line going from the back of the block to the intake manifold. The line going from the front of the block to the intake tube prior to the throttle body can be vented to atmosphere, just plug the hole in the intake tube and put a filter on the end of the hose. If the can is simply hollow, steal wool isn't a bad idea. I've also heard of plastic alternatives, but I'd stick with steal as I'm not sure how the plastic will deal with the corrosive gasses.
Old 01-20-2013, 08:41 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
You know, the Cusco unit is actually a beautifully made piece. So much so that there are actual counterfeits in the market.
The flaw with this unit is the incorrect Japanese instructions showing a hookup to the front crankcase vent but not the PCV. Also there is no fitting provided to attach the supplied tubing of 15mm to the 9 mm PCV outlet barb. Then there's the absence of an internal baffle which makes me wonder how much oil mist will actually separate from the air under vacuum.
I just removed one of the outlet barbs on the can and worked in a bunch of fluffed up wads of stainless steelwool. That should provide a decent baffle between the inlet/outlet.
Old 01-20-2013, 09:15 PM   #6
Calum
That Guy
I'd sell it and get one of these.
http://www.jegs.com/p/JEGS-Performan...63433/10002/-1
Old 01-20-2013, 09:29 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Calum View Post
I am sure you would.
Old 01-21-2013, 10:01 PM   #8
tonytduc
tonytduc's Avatar
Where did you get the fitting? 15mm to 9mm
tonytduc is offline   Reply With Quote
Old 01-21-2013, 10:53 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
You know the grey sound tube that TRD makes interchangeable sets in red, blue and green? Since I have removed the whole growl tube tubes and plugged the firewall I used the stock grey tube. Reamed it out inside before to remove foam and a restrictive plastic criss cross. It works but dunno about temperature since my car is garaged. Frankly, I'm looking for any better solution.)
Old 02-24-2014, 10:49 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
For future notice, the 15mm to 9mm hose adapter can be purchased. Vividracing, FRSport, and FT86 Speedfactory all have that adapter.
http://www.vividracing.com/catalog/c...-p-114206.html
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
AP Pulley - Cusco Oil Catch Can TeamSweet86 Engine, Exhaust, Bolt-Ons 9 02-22-2013 02:25 PM
Password JDM w/ Cusco Catch can?? tonytduc Scion FR-S / Toyota 86 GT86 General Forum 0 01-17-2013 12:21 AM
Cusco catch can install wbradley Engine, Exhaust, Transmission 2 01-11-2013 01:11 AM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 04:16 AM
Cusco Street Oil Catch Tank 0.6L in stock!!! IslandImportPerformance Engine, Exhaust, Bolt-Ons 0 06-05-2012 01:56 AM
