Old 12-07-2011, 09:19 PM   #1
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
“saddle-shaped” fuel tank
The car will come with a “saddle-shaped” fuel tank. Do you guys think it will also have a positive side effect and act as "baffles" to prevent fuel starvation under high g-load?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 12-07-2011, 09:35 PM   #2
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I highly doubt this car is going to have any fuel starvation issues. Yes, I think the saddle will help, however; I thought its designed in such a way as to be centered under the chassis as much as possible.
chulooz is offline   Reply With Quote
Old 12-07-2011, 09:39 PM   #3
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Saddle shaped fuel tanks have been in production for a while now. It should be ok as long as it has an ejector pump.
http://www.patentgenius.com/patent/5133324.html
Old 12-08-2011, 08:23 AM   #4
ft86Fan
ft86Fan's Avatar
Originally Posted by Driftster View Post
lol my 80's cadillac had a saddle tank..
I'm guessing your 80's Cadillac does not have fuel starvation issue so I guess it does work
you guys dig too much into this car for possible "performance adds"
I know I know....
Old 12-08-2011, 08:55 AM   #5
ft86Fan
ft86Fan's Avatar
Thanks for the link. Does all saddled shaped tanks use an ejector pump?
Old 12-08-2011, 09:30 AM   #6
spin9k
spin9k's Avatar
Drives: RX-8
Let's hope. In the RX-8 the similar type tank it is the cause of fuel starvation when below 1/3 to 1/4 full. Not fun, but not killer either, just very consistant and so one needs to keep above that level to avoid an embarrassing fuel cutout sputtering after high G turns. Of course, this ONLY happens on a racetrack circuit.
Also the tank is direclty under the back seat cushions, just pull them up and you can remove the cover and fuel pump and peer into the tank (#3).
spin9k is offline   Reply With Quote
Old 12-08-2011, 11:53 AM   #7
chulooz
Registered you sir
chulooz's Avatar
Thanks for the info! Did the rx8 guys or mazda never develope a solution to the issue?
Old 12-08-2011, 12:11 PM   #8
spin9k
spin9k's Avatar
Drives: RX-8
I haven't really been paying attention as I treat it only a nusiance, keep filling the tank. But on rx8club it's always been a popular topic, Mazda has upgraded the pump in '09 but that's all I know. Many race teams have a fix, but they don't talk much, and it's $$/work I'm sure.
Old 12-08-2011, 02:25 PM   #9
ft86Fan
ft86Fan's Avatar
I don't think its the "saddle-shape" that is causing fuel starvation. If anything, it is better than a flat bottom fuel tank with no baffles.
Old 12-08-2011, 03:06 PM   #10
ryude
Drives: Volkswagen GTI
My mustang gt had saddle shaped fuel tank as well, its a pretty common setup.
ryude is offline   Reply With Quote
Old 12-08-2011, 04:07 PM   #11
spin9k
spin9k's Avatar
Drives: RX-8
My bad, didn't mean to infer the "saddle shape" was or was not the problem as I have no idea. I meant the gas tank .. something in there .. is the problem! Wish I knew
Old 06-24-2012, 06:10 PM   #12
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Saddle tanks are a problem in the newer STis because there is only one fuel pump and then a siphon system on the other side. Now even without the saddle tanks the older STis have fuel starvation issues below half tank (if you're fast on the track).
The FRS has been really good for me while racing but I did pick up some fuel starvation around half a tank in a hard left turn followed by a long right sweeper (on racing slicks). We fix the STis by using two fuel pumps but I need to look more into the FRS system to see if it's similar to the STi where the surge tank on the passenger side is feed by the siphon on the driver's side.
Element Tuning is offline   Reply With Quote
Old 06-25-2012, 09:30 PM   #13
subaruferrucci
Drives: FR-s
I know some autoX use an RC airplane/car fuel tank. They would put it over the fuel pump and make sure it captures the return. The RC tank had a few holes cut into it so that it could rejoin the main fuel system and levels could balance out. but if you hit a hard turn where fuel starvation is an issue the RC fuel tank will hold fuel level slightly higher for the moments when it is needed and prevent the starvation.
keep in mind this was on an old subby 2.2 impreza and an AUTOX car so the amount of time needed to keep fuel in one spot might not need to be as much
subaruferrucci is offline   Reply With Quote
Old 06-26-2012, 05:22 AM   #14
Jonny Rochester
Drives: 1983 Corolla Levin
The 86 only has one fuel pump (fuel filter and pump is in the one assembly, and in the tank on the left side). It uses the venturi effect to suck fuel from the other side.
Jonny Rochester is offline   Reply With Quote
Safety: BRZ has reinforced ring-shaped frame tranzformer BRZ First-Gen (2012+) — General Topics 1 12-06-2011 09:40 AM
What fuel spec. smbrm Scion FR-S / Toyota 86 GT86 General Forum 6 06-19-2010 10:32 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 04:50 PM
E85 Fuel? Siriusly.Andrew Scion FR-S / Toyota 86 GT86 General Forum 60 02-11-2010 06:00 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 03:55 AM
