Old 01-30-2013, 11:37 PM   #1
cruzinbill
Drives: Argento 6spd FR-S
Oem amp connectors
Anyone have a clue where I may acquire the female side connectors for the oem amp. That's the side that's in the amp btw.
cruzinbill is offline   Reply With Quote
Old 01-31-2013, 09:49 AM   #2
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
It's a standard old school Toyota harness:
[ame="http://www.amazon.com/Metra-70-1761-Wiring-Harness-Speaker/dp/B0002BEQJ8"]Amazon.com: Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker: Car Electronics[/ame]
Of course the colors are different - you'll need to match the pinout with our wiring diagrams ...but it'll plug right in
rmjjensen is offline   Reply With Quote
Old 01-31-2013, 10:44 AM   #3
cruzinbill
Im looking for raw conncectors for the amp in the rear not a harness for the head unit. Im working on a custom project not for swapping the Headunit.
Old 01-31-2013, 11:51 AM   #4
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Do tell
I'm hoping you are planning a breakout cable. I think that would help the people that want to keep the head unit and integrate a DSP.
rupert is offline   Reply With Quote
Old 01-31-2013, 12:41 PM   #5
cruzinbill
Originally Posted by rupert View Post
Do tell
Nothin to really tell right now, still seeing if I can even find the things Im wanting.
Old 01-31-2013, 03:14 PM   #6
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
The two sockets on the factory amp are the same physically as the power/speaker sockets on the HU. Thus, the same Toyota "forward" harness ("female") will fit the amp's factory harness plugs ("male").
As rmjjensen said, you might want to re-pin the aftermarket harnesses (easy to do) so the wire colors make more sense for the amp.
SVXdc is offline   Reply With Quote
Old 01-31-2013, 03:48 PM   #7
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Is this the kind of thing that would work towards just adding an additional sub to the amp in back easily without pulling up trim/carpet from the HU?
oldpueblo is offline   Reply With Quote
Old 01-31-2013, 04:56 PM   #8
cruzinbill
No Shit!? I didnt realize it was that simple. I was wondering why he linked female connectors for behind the HU lol.
Thanks folks, just made things so much easier.
Old 01-31-2013, 04:57 PM   #9
cruzinbill
Your not gonna want to try powering a sub off the oem amp. getting the remote turn on is prolly as far as you would go. You would still need to run RCAs to the head tho. But, that takes maybe 10-15 mins.
Old 01-31-2013, 06:35 PM   #10
SVXdc
SVXdc's Avatar
If you have a BRZ, or any other model whose OEM HU does not have the sub RCA jacks, then yes you could tap into the inputs going into the factory amp (speaker outputs coming from the HU) -- to feed to the inputs of another amp to drive your bigger sub speaker.
You'll still need to grab the main power for your new amp directly from the battery, as usual.
If you want to replace the OEM amp with a small 3-channel amp (is there such a thing?) -- to continue driving the door speakers and add a channel for a new sub -- you might get away with using the OEM power wire.
I don't recommend trying to hang too much off the the OEM HU's amp remote turn-on lead. Until someone can find a service manual, there's no telling how much current each OEM HU can provide on that lead.
Old 01-31-2013, 06:47 PM   #11
cruzinbill
you can always just use the oem turnon with a relay tho if you need to turn on multiple devices.
