Old 02-03-2013, 12:23 PM   #1
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
DIY Alignment
I'm thinking once I install my new springs and adjustable suspension bits I'll do my own alignments.
Doing some research and I've come up with 3 possible camber/caster/toe gauges. Anybody have any experience with these and can offer some feedback to them?
LongAcre - Concerned it won't mount to the wheel. http://www.longacreracing.com/catalo...d=1580&catid=5
FastTrax - you can get a Toe measure add on. Non digital. Uses bubble measure and I'm concerned about accuracy.
http://www.jegs.com/i/Specialty-Prod...10#moreDetails
QuickTrick - This is the one I'm leaning toward. Has a separate Toe gauge.
http://www.quicktrickalignment.com/s...tem-with-case/
FRSFirestorm is offline   Reply With Quote
Old 02-03-2013, 03:54 PM   #2
d1ck
Drives: Black 2013 FRS
Jesus, that QuickTrick system looks awesome.
d1ck is offline   Reply With Quote
Old 02-03-2013, 04:33 PM   #3
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
The QuickTrick looks interesting. Please if you don't mind write a review if you do get it. Thanks.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 02-03-2013, 04:39 PM   #4
mact
Drives: 13 GTI
Interesting. I would love to hear a review on the QuickTrick kit. My dad's alignment on his car is so bad that any adjustment would make it better.
mact is offline   Reply With Quote
Old 02-03-2013, 04:56 PM   #5
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
If you like to buy tires every 6 months cause they are worn out because a "string" or "bubble" alignment... lol go ahead
Alignment shops are cheap, just find a good one and work a deal with them if you need multiples.
JesseE is offline   Reply With Quote
Old 02-03-2013, 05:28 PM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I've got this camber gauge:
http://www.toyheadauto.com/CasterCamberGauge.html
It's cheap and effective. It does not work very well with 17" wheels (at least not my version).
I also use Longacre toe plates. [ame="http://www.amazon.com/Longacre-Toe-Plates-Includes-Tapes/dp/B000VAOHB2"]Longacre Toe Plates (Set) Includes (2) Tapes : Amazon.com : Automotive[/ame]
Between my cars, and all the people I've loaded the plates to, thousands of dollars have been saved.
celica73 is offline   Reply With Quote
Old 02-03-2013, 05:33 PM   #7
Hardrock4445
Hardrock4445's Avatar
How often you planning on aligning your vehicle? For the range of 200-300 I would think you could get a few alignments on a true alignment rack by a professional. I would think for such a new car that had no rusted/frozen bolts you should be around 80-100 bucks for a 4-wheel align.
Hardrock4445 is offline   Reply With Quote
Old 02-03-2013, 05:39 PM   #8
FRSFirestorm
Red is Fastest
Looks like I may be the guinea pig.
Thanks for the ummm..... warning. I'll take it in consideration. From the research I've done, string and bubble alignments can be done quite accurate if done properly.
There are several reasons I want to do it myself. I won't go into them. The purpose of this post was not to debate the logic of doing your own alignments but to ask about the equipment available out there to do them.
Old 02-03-2013, 05:45 PM   #9
FRSFirestorm
Red is Fastest
I also use Longacre toe plates. Longacre Toe Plates (Set) Includes (2) Tapes : Amazon.com : Automotive
I've seen those tools in a couple DIY alignment pages and were the first I looked at when starting the search. Guess I'm willing to spend a bit more money to go digital.
Old 02-03-2013, 05:53 PM   #10
FRSFirestorm
Red is Fastest
Really don't know how many I'll do. Obviously the first and I like the idea of tweaking it a bit and then checking it ever so often. I like doing things myself and I'm in the middle of Smallsville KY. Any good shop I find would likely be hours away and an all day event when you count travel. Its more about time than cost. Along with the satisfaction and assurance its done right by doing it myself. In the past alignments are one of the very few things I've had a "professional" perform on my vehicles. They weren't all pleasant experiences.
Old 02-03-2013, 06:07 PM   #11
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I am similarly intrigued. I may just pick one up myself.
FrX is offline   Reply With Quote
Old 02-03-2013, 06:29 PM   #12
Hardrock4445
It is unfortunate that some people cannot provide a proper service to people, I know some shops in my area won't do 4 wheel align for less than 150. I charge depending on variables, amount of adjustments, age of vehicle, rust. Etc, I usually work out a price with my customers rather than a set price.
Old 02-03-2013, 06:38 PM   #13
FRSFirestorm
Red is Fastest
Just ordered it. I'll do a review/writeup whenever I put it to work. May be a while.
Old 02-03-2013, 06:42 PM   #14
FRSFirestorm
Red is Fastest
Wish you were close. Sounds like you'd fall into the "good shop" category.
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-10-2012 12:36 AM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 08:48 PM
Got my Alignment done at Revworks jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 10-31-2012 12:13 PM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 12:41 PM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
