Old 02-04-2013, 06:30 AM   #1
Pvt AJ
Pvt AJ's Avatar
Drives: Toyota 86 GTS
Modellista Antenna Instructions
Does anyone have the instructions for the Modellista antenna in English?
I have the Japanese instructions and it would take some time for me to translate it.
Pvt AJ is offline   Reply With Quote
Old 02-07-2013, 03:54 AM   #2
Pvt AJ
Pvt AJ's Avatar
Modellista Antenna Instruction Translation
Disclaimer: I am not responsible for any damage you may do to your vehicle, this is just a rough translation from the instruction manual provided with the modellista antenna.
Page 3-2:
  • Remove the genuine antenna.
  • Measure the size of the base with the reference figures A & B, to know which adapter to use.
  • Coat the inside of the antenna base with primer, using the double sided tape provided.
  • Firmly attach the antenna base whilepushing the left and right sides of the adapter.
  • Attach the convex portion of the antenna to the base.
  • Align with the centre of the body; align with the marking sticker on the roof panel.
  • After aligning with the body, place masking tape along the perimeter.
  • After priming, remove the cover on the double sided tape.
Page 3-3:
  • Attach the screw to the body with the washer provided.
  • Fix to the antenna using the aligning ribs previously fixed to the antenna.
  • Before securing the antenna to the body, make sure notes A ~C have been checked before fixing. Do this in a state of temporary fixing.
    • A:Check the orientation is correct.
    • B: Make sure the screw is secured correctly.
    • C: Make sure the antenna lead is secured into the cradle position as in diagram.
  • Align the marking stickers to orientate the front, and then remove the stickers.
  • Press firmly all around the antenna and let it set.
I hope this helps anyone in need and i will be installing the antenna within the next few weeks.
Old 03-02-2013, 12:11 AM   #3
stea1thbear
Drives: Scion FR-S Firestorm
Page 3-2:
Page 3-3:
Thanks! Just got my modellista antenna, but I have opti coat on my car so I'm trying to figure out the best plan of action. Did you have opti coat on your car?
stea1thbear is offline   Reply With Quote
Old 03-02-2013, 02:51 AM   #4
Pvt AJ
Pvt AJ's Avatar
No opti coat on my car, but the double sided tape on it should hold up just fine, lots of opti coat appliers have put on fin atennas after doing it and theres been people put on spoilers also.
Old 03-02-2013, 04:10 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Pics of your antenna installed?
Old 03-02-2013, 05:12 AM   #6
Pvt AJ
Pvt AJ's Avatar
Yep as soon as the sun comes up, ill take some detail photos.
Old 03-02-2013, 09:51 AM   #7
spgrizz22
Drives: Scion FR-S
I'm planing on buying it so I wanted I se it!
spgrizz22 is offline   Reply With Quote
Old 03-02-2013, 06:54 PM   #8
Pvt AJ
Pvt AJ's Avatar
Here are the pictures:
Old 03-02-2013, 07:06 PM   #9
Pvt AJ
Pvt AJ's Avatar
next lot:
Old 03-02-2013, 07:29 PM   #10
spgrizz22
Drives: Scion FR-S
Too Sexy!!
Old 03-14-2013, 05:41 PM   #11
Toxic78
Toxic78's Avatar
Drives: BRZ - Dark Grey
Any idea if this will fit the BRZ?
Toxic78 is offline   Reply With Quote
Old 03-14-2013, 06:03 PM   #12
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
USDM BRZ - Nope. Rest of the world - Yep.
The US antenna base is to large for the Tom's, Modellista or "normal" sized Beat Sonic piggy back antennas to fit.
VG and Beat Sonic make one that is large to accept the US BRZ antenna.
Beyer Subaru is offline   Reply With Quote
Old 03-14-2013, 06:39 PM   #13
Toxic78
Toxic78's Avatar
I like the modellista the best, regardless if its so pricey but since it won't fit the USDM - guess its RC style for now in hopes of someone making a USDM alternative to VG or Beat's.
Old 03-14-2013, 06:52 PM   #14
Beyer Subaru
Yep. I yanked the factory RC antenna and stowed it in between the ceiling/roof. I plugged the hole with a color matched Legacy antenna until we find out more about the JDM BRZ version.
antenna, diy, fin, instructions, modellista
TRD bumper garnish fitting instructions in English APS86 Cosmetic Modification (Interior/Exterior/Lighting) 9 11-16-2018 12:29 PM
Wheel Directory: OEM Toyota 86 (JDM Modellista Wing Dancer II) 18x7.5 +46 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-23-2013 08:22 PM
WTT: Beat-Sonic Antenna for Modelista Antenna joergasm Canada Classifieds 4 12-10-2012 10:13 AM
Instructions for dash disassembly whataboutbob Cosmetic Modification (Interior/Exterior/Lighting) 3 07-01-2012 08:03 PM
Modellista for FR-S vividracing Exterior Parts - The Rest 15 06-27-2012 09:53 PM
