Ontario's FT86
Drives: 2016 Lexus GS-F
Rattle at idle when clutch engaged in netural
Hi guys,
I have this pretty loud rattle at idle when the clutch is engaged in neutral. Here is a video, can you can see when I depress the clutch, the sound will be gone. This was my first manual car and I was wondering if this was normal? [ame]http://youtu.be/uj3VgzO0IhA[/ame] Thanks, Shu |
Drives: Silver FRS
don't hear that on mine.. maybe some of your panels are loose under the car?
Red wine
Drives: Subaru BRZ(R.I.P)
Loose clutch assembly? Have someone else step on the clutch while you inspect it. If you can/cant find anything just take it to the dealership and have them take care of it under warranty.
Ontario's FT86
O btw, I have the whileline shifter bushing and perrin trans mount... Maybe they magnified the sound?
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
I have this exact noise. If i press the clutch, it is gone. Doesn't always do it.
Drives: '13 Ultramarine
This is fairly common in RWD vehicles with manual transmissions. My Mustang is really noticeable under the same conditions. My FR-S isn't as loud, but your harder bushings may have something to do with that.
Drives: toyota gt 86
its the shafts in the gearbox moving, even though your in nuetral your gearbox input shaft and bearing are still rotating, when you put your foot on the clutch it stops the box from turning, i bet its cold when this is happening yes ?
Drives: 2017 Halo 86
@shu5892001 Did you ever resolve this? I have this issue too with AC on only and clutch out, doesn't matter hot or cold.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
Drives: 2023 BRZ
Mine does something similar. Could it be loose clutch springs?
Director of Rocky Mountain 86CUP
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
| Transmission rattle while revving in gear with clutch both engaged and disengaged | robo_robb | Engine, Exhaust, Transmission | 2 | 06-16-2012 02:35 AM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
