Old 02-07-2013, 10:31 PM   #1
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
The reason I'm always broke - Dustin's Supercharged 86
After waiting what seemed like an eternity I finally got my car. I made a 573 mile trip to Nebraska to pick up the FRS I want. Yes the trip was a bit excessive but it was good fun.
Engine/Transmission/Drivetrain
Installed Delicious Tuned Innovate Supercharger Stage 2 w/ intercooler - 285 whp 219 lb/ft tq
Installed Raceseng 70mm supercharger pulley
Installed Nameless Performance long tube EL header
Installed Nameless Performance 3" OP/FP combo
Installed Nameless Performance 3" Mid pipe
Installed Nameless Performance 3" Axle back
Installed ACT Clutch and Flywheel
Installed MTEC Stainless steel braided clutch line
Installed Full Blown Radiator/Fan Shroud combo with SPAL fans
Installed Weir Performance 4.56 Ring and Pinion
Installed Tomei 2 Way Limited Slip Differential
Installed Aluminum Carrier Bushings - my design
Installed Forcedfab Transmission mount stiffener modified to fit Whiteline bushing
Planned TRD Short Shift Kit
Planned 1 Piece Aluminum Driveshaft
Planned K&N drop in
Planned Oil Cooler
Planned Fully built motor and a Sprintex 335 blower when I get bored with what I have now
Suspension
Installed H&R Super Sport Lowering Spring
Installed Nameless Performance Lateral Bars
Installed Perrin Steering Rack Lockdowns
Planned Nameless Performance Strut Tower Bar
Planned Ohlins Coilovers w/ Extended Tophats
Planned RacerX Suspension components
Planned Caged when the kids no longer fit in the back seat
Exterior
Installed Subaru Outback Fog Lights with OEM bezels and PIAA yellow lights
Installed Front and Rear Toyota Badges and removed FRS badge
Installed JDM Style clear side markers
Installed Beat Sonic Shark Fin antenna
Installed Resprayed tails with VHT Red spray paint
Installed 18" RH Evolution C2's wheels
Installed 35% Tint on the front and 5% on the back
Planned VIS AMS Carbon Fiber Vented Hood
Planned VIS AMS Carbon Fiber Trunk
Planned TRD Lip Kit
Planned Buddyclub Tail Lights
Planned JDM Head Lights
Planned Different wheels - undecided
Interior
Installed Toyota Tundra headlight/fog light stalk
Installed 7th Gen Celica GTS Throttle Pedal
Installed Cusco Spin Turn Knob
Planned Rear seat delete when kids no longer fit
Planned Bride Seats
Planned Weighted Shift Knob
Planned JDM Knee Pads
Planned BRZ Shift Boot
02/18/13 - Purchased Whiteout FRS #661
Page 1
02/23/13 - Rebadged exterior and removed FRS emblem
02/25/13 - 35% tint on front windows and 5% on back
02/26/13 - Sprayed tail lights
Page 2
02/27/13 - Rebadged key
04/10/13 - Lowered on H&R Super Sport springs
04/24/13 - Busted my AC condensor so replaced with new OEM unit
06/01/13 - BWR license plate hardware kit
06/29/13 - 18" RH Evolution C2's
Page 3
08/31/13 - Installed Whiteline Positive Shift Kit and received Weir Performance 4.56 Ring and Pinion gear set
09/03/13 - Installed modified ForcedFab transmission mount stiffener
Page 4
12/09/13 - Received Tomei 2 Way LSD
12/21/13 - Removed 3rd member from car and removed factory differential and ring gear. Installed Weir Performance ring gear on Tomei 2 way
My 6 year old son being my helper
12/25/13 - Received Nameless Performance 3" catted and resonated overpipe/downpipe combo and fog lights
01/04/14 - Started designing carrier bushing
01/10/14 - @Rue & Boston Mike (not on this forum) machined my bushing inserts out of 1" 304 stainless round bar.
01/11/14 - Installed Toyota Tundra stalk for fog lights.
Page 5
01/24/14 - @Rue & Boston Mike finished machining and installed the aluminum carrier bushings with stainless steel inserts.
01/25/14 - Installed carrier with Tomei 2 way, Weir Performance 4.56 ring and pinion, and aluminum carrier bushings, my design, made by @Rue and Boston Mike.
01/25/14 - Installed fog lights and 7th gen Celica GTS throttle pedal installed for better heel/toe.
01/26/14 - Installed Cusco spin turn knob that I got as a freebie.
Page 6
02/14/14 - Received Innovate Stg 2 supercharger
02/22/14 - Received Raceseng 70mm pulley
02/24/14 - Received ACT clutch and flywheel & MTEC clutch line.
03/11/14 - Received Nameless header
03/14/14 - Received FBM radiator/fan shroud combo
Page 7
03/18/14 - Installed Nameless header and Nameless OP/FP combo
03/29/14 - Installed FBM radiator/fan shroud combo.
04/09/14 - Received & installed Nameless 3" mid pipe and axle back and Nameless lateral bars
04/09/14 - Received Nameless intake for the Innovate supercharger - no longer installed
04/22/14 - Purchased tune from Delicious Tuning
Page 8
04/25/13 - Supercharger manifold machined, got Honda MAP sensor, and MAP sensor/IAT sensor plate designed by my brother.
04/26/14 - Installed ACT clutch and flywheel and MTEC clutch line.
04/28/14 - Received EcuTek software with Delicious tune.
04/30/14 - Ordered GM open element IAT sensor
05/01/14 - New IAT/MAP sensor plate finished by @Rue
05/03/14 - Installed Innovate supercharger with Raceseng 70mm pulley, Nameless intake tube, and all running with a tune from Delicious Tuning.
Page 9
05/12/14 - Installed Beat Sonic shark fin antenna
06/24/14 - Dyno'd 285whp & 219 lb/ft torque
Page 10
08/09/14 - Received Perrin Steering Rack Lockdowns
10/04/14 - Installed Perrin Steering Rack Lockdowns
To Do List
Oil Cooler
Ohlins coil overs
RacerX suspension components
And lots more.......
Plenty more pics to come!!
Dustin is offline   Reply With Quote
Old 02-07-2013, 10:34 PM   #2
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Congratulations on your purchase! At least you'll be able to get some miles in and get closer to that break in period lol. I am also awaiting my frs, can't wait!
JohnAyySays is offline   Reply With Quote
Old 02-07-2013, 11:43 PM   #3
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Fellow Dustin and FR-S owner here Welcome to the club!
Kuzuri is offline   Reply With Quote
Old 02-08-2013, 10:21 AM   #4
Dustin
Twin Screw You
Dustin's Avatar
Thanks, it already has 5k miles on it so it should be broken in already. But it'll still be fun putting some miles on it none the less.
Thanks Dustin!!
Old 02-17-2013, 07:39 AM   #5
Dustin
Twin Screw You
Dustin's Avatar
My brother made the trip with me. He's one of the reasons I'm getting this car. He has owned an original AE86 for going on close to a decade and he's pretty stoked I'm getting this. If I didn't trade in a car on the FR-S, I would've made the cruise in his Levin.
Old 02-17-2013, 08:54 AM   #6
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Congrats on reaching the big day and enjoy the ride home!
Alan is offline   Reply With Quote
Old 02-17-2013, 02:03 PM   #7
Turbowned
Turbowned's Avatar
Congrats man! Your brother's car is siiiiiick!!!
Old 02-18-2013, 10:54 AM   #8
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Mmmm blacktop... Good luck! Hope you like it.
FReSh is offline   Reply With Quote
Old 02-19-2013, 04:13 AM   #9
husker741
Congrats man! I actually looked and considered that exact car but I just went and ordered a new one at the Scion dealership in Omaha.
husker741 is offline   Reply With Quote
Old 02-20-2013, 12:48 AM   #10
suaveflooder
where are the new pics!?!?!?!? Congrats! Just picked mine up last week! Beyond happy with my purchase!
suaveflooder is offline   Reply With Quote
Old 02-20-2013, 08:57 AM   #11
Dustin
Twin Screw You
Dustin's Avatar
My camera battery was dead before I left. And to be honest, all day yesterday was me catching up on sleep. I was up pretty much he whole 23 hours of the trip going off of about 5 hours of sleep from the night before. I'll try to get some pics today.
Old 02-20-2013, 08:17 PM   #12
Dustin
Twin Screw You
Dustin's Avatar
It's been raining today so no pics. But I did pick something up for it today. Nothing big but then again I won't be getting anything big for it for a while. I'll try to have it done by this weekend when the weather is better.
Old 02-20-2013, 11:41 PM   #13
Dustin
Twin Screw You
Dustin's Avatar
I did take one pic today. A little hazy but eh..........whatever.
Old 02-21-2013, 12:04 AM   #14
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Where did you pick it up in Nebraska, curious lol. At least you made it home before the snow storm that is about to ravage us here in Nebraska.
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) runny_yolk Electronics | Audio | NAV | Infotainment 120 01-29-2021 07:18 PM
step 1 :buy frs in phx, step 2: drive to pikes peak haymaker FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 08-21-2012 11:44 AM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 12:38 PM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 12:27 PM
