Old 02-13-2013, 03:35 PM   #1
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
End Links
So my aftermarket endlinks are shot. I was curious If the OEM ones will work or if they would be to long.
Chen is offline   Reply With Quote
Old 02-13-2013, 03:44 PM   #2
xwd
What brand? With some of the budget coilovers out there they will be too long. You can get decent adjustable front endlinks from both Hotchkis and Whiteline.
Old 02-13-2013, 03:46 PM   #3
fatoni
how did you ruin endlinks that fast? also, there is no way anybody can answer that question without you providing any information. its probably pretty cheap to just rebuild the endlinks. why dont you just swap them out and see how it goes? endlinks arent hard to get at.
Old 02-13-2013, 03:55 PM   #4
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
In to hear how you busted your endlinks, who made them?
chulooz is offline   Reply With Quote
Old 02-13-2013, 03:55 PM   #5
Chen
Regional Moderator
Chen's Avatar
I got the stance coils. I looked at some whitelines. But I was worried about length.
I bought used coilovers. and the end links I received looked like there was an impact gun used on them so now they don't tighten all the way and I hear clinking noises when driving on crappy roads.
Old 02-13-2013, 03:58 PM   #6
Chen
Regional Moderator
Chen's Avatar
I personally didn't. I'm just here to get info on how to fix them. I was told the end links I have are usable, and if I can get past the noise. I won't have to worry about it.
Old 02-13-2013, 04:51 PM   #7
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have the rear Perrin poly endlinks and they are working good. They haven't made a front endlink yet. For the front I'm just using the stock front ones though. Perhaps the Whiteline front endlinks would be good. I'm not dropped as low as you as I'm just at 1".
stockysnail is offline   Reply With Quote
Old 02-13-2013, 06:20 PM   #8
Chen
Regional Moderator
Chen's Avatar
at this moment i'm just trying to figure out if the OEM ones will work. I might just pick up the whiteline endlinks if it doesn't work out tho.
Old 02-13-2013, 06:23 PM   #9
OrbitalEllipses
Drives: Attitude
2008+ WRX/STI rear endlinks work for the rear of this car, even if not advertised as 86 fitment.
Kartboy and his endlinks have been in the game since '99.
Old 02-13-2013, 06:34 PM   #10
stockysnail
Just the tip
I wouldn't risk it if you've dropped your car 2". They have too much preload tension on them more than likely, thus making their lifespan much shorter. That's my mildly educated guess anyway.
Old 02-13-2013, 06:35 PM   #11
jamal
jamal's Avatar
Drives: Legacy GT
Seconding Kartboy for rears. My KB endlinks are going on 7 years old now.
Not sure what is out there for the front.
jamal is offline   Reply With Quote
Old 02-13-2013, 06:43 PM   #12
Chen
Regional Moderator
Chen's Avatar
I was told the OEM ones would work. I just wanted to make sure they were the same length.
Old 02-13-2013, 07:43 PM   #13
Turn in Concepts
Turn in Concepts's Avatar
Kartboy rears for the rears.
Fronts are a crapshoot right now until we or Tom can figure something out.
Turn in Concepts is offline   Reply With Quote
Old 02-13-2013, 09:04 PM   #14
Chen
Regional Moderator
Chen's Avatar
agreed. -_-
Links to frs for sale? Please help DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 17 01-18-2013 06:41 PM
Links to used FR-S DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 0 01-18-2013 12:12 AM
Rear Toe Links? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-05-2012 06:29 PM
Wheel reference links JDLM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-27-2012 04:22 AM
