Old 02-17-2013, 02:32 PM   #1
mrbbs
Drives: GT86
Which LSD to take: Cusco or OS Giken
Hi,
I would like to replace my original LSD with a Cusco or OS Giken one (1.5 way).
Use: fast road trips, hand brake use, rally minded driving on narrow mostly bumpy b-roads
Can you anyone explain difference between Cusco RS or OS Giken Spec S/X?
Thanks!
Kevin
P.S. Will be placing a Cusco 4.81 final drive along.
mrbbs is offline   Reply With Quote
Old 02-17-2013, 10:24 PM   #2
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
havent had either but os giken is in alot of competition cars. id pick them
IG-Joey_Soul
Old 02-17-2013, 10:33 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
I have a Cusco RZ in my TA22 Celica and i love it. Smooth engagement but it locks solid when needed.
I haven't driven a car with an OS Giken but i have heard nothing but good things about them. I would have to check but i think they run more friction plates than most other LSDs on the market.
1974 TA22 Celica
2013 86 GT
Old 02-17-2013, 10:33 PM   #4
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by mrbbs View Post
Hi,
Thanks!
Kevin
Cusco make a 4.556 final drive and have an LSD to suit Toyota 4.875 and 5.125 final drive. I can't find information on a 4.81 one.
I ordered the Cusco 1.5/2 way with 5.125 gears. I'll set it up as 1.5 to start with, then will try it as a 2 way.
86drift is offline   Reply With Quote
Old 02-18-2013, 02:48 AM   #5
mrbbs
Drives: GT86
Correct, I meant the 4.875 one. What make LSD will you take?
Old 02-18-2013, 03:09 AM   #6
Z3D
Try some Grateful Dead skulls or some Albert Hoffman 50th Anniversary.
Z3D is offline   Reply With Quote
Old 02-18-2013, 03:39 AM   #7
86drift
86drift's Avatar
I may be wrong, but that final drive won't work with the OS Giken LSD. Make sure you check before you buy.
I'll take any type of LSD...
Old 02-18-2013, 04:44 PM   #8
mrbbs
Drives: GT86
Thanks for the note, I'll pay attention.
I heart the OS Giken LSD will give less understeer while light throttle is applied and will be more progressive with their patented design with more plates.
By this design there also would be less heat in the diff and so also less wear.
Old 02-18-2013, 08:08 PM   #9
wootwoot
Drives: FRS
What he said....
wootwoot is offline   Reply With Quote
Old 02-18-2013, 08:17 PM   #10
mashal
DADA
mashal's Avatar
Drives: 2013
Originally Posted by wootwoot View Post
What he said....
What they said
mashal is offline   Reply With Quote
Old 11-29-2014, 12:10 PM   #11
GT86_PRAGUE
Drives: GT86
Hi, how that worked out? Thanks...
GT86_PRAGUE is offline   Reply With Quote
Old 11-29-2014, 03:27 PM   #12
whataboutbob
AutoX-10/10ths every run
I put the Cusco 1.5RS with a 4.556 final in my Sprintex SC'd automatic twin. The LSD and final drive made a huge difference on the autocross courses. I can get on the throttle so much earlier on corner exit and the final drive really helps the car accelerate more quickly. The final drive change did make it necessary to shift to 3rd on some of the faster sections of the autocross course.
Build thread:Here
Old 11-29-2014, 07:48 PM   #13
troek
troek's Avatar
Drives: 2012 Toyota 86
The csg guys have alot of experience with these. Id talk to them.
Old 11-30-2014, 07:55 PM   #14
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I remember my cusco rs 2 way I had in my old s14. Worked very well but was pretty aggressive for daily driving.
Can't go wrong either way in my opinion.
TylerLieberman is offline   Reply With Quote
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 01:17 PM
A really good comparison between OS Giken and Cusco Erik @ GBox Engine, Exhaust, Transmission 1 10-19-2012 11:50 PM
GBox Joins the club - Group purchase OS Giken LSD. Erik @ GBox Transmission and Driveline 0 10-17-2012 04:42 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 04:24 PM
