| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
I usually post drunk
Car won't start, no spark?
2003 accord 4 cylinder with 100k miles.
Worked perfectly driving home from work the night before. The next day trying to go to work it won't start. The engine turns over but doesn't start. Jump start didn't work. There is no check engine light but I have no way of checking for codes anyway. Disconnecting the fuel line from the fuel rail lets gas come out and the fuel pump makes noise so it seems to be working. Putting a screw driver into a spark plug does not create spark. Also, there is a collapsed radiator hose, don't know why Do not know where to go from here? |
Thee O-ri-gi-na-tor
first check everything ignition related i.e spark wires, distributor cap and rotor and even fuses
Drives: 2009 Hyundai Sonata
Sounds a lot like a problem I had at 40k with my Sonata. The starter went bad. If its a manual transmission, try to push-car start it.
Visit my blog about car enthusiasm!
http://theelitistenthusiast.blogspot.com/ |
hmm, so I tried to jump the car on Friday when I originally had the problem.
Used my friends charger/jumper that plugs into outlet on Saturday. Both didn't work. When the mechanic use his jumper pack, the car starts. He finds no codes and says the alternator is working fine. ........ |
Grumpy Old Man
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Could be an issue with intermittent connectivity at the ignition switch. My GS-R had that problem. Though with my car it was IGN switch to the fuel pump relay that was the issue.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
Feeling Iffy?
Drives: it like I stole it
I have a 2000 accord and I replaced my starter and spark plugs at around 100K. A starter might run you a few hundred but I'm sure you have plenty more miles left in your car. I'm on 196K right now.
| No push button start a good thing? | Syldrin | Scion FR-S / Toyota 86 GT86 General Forum | 130 | 12-13-2011 08:06 PM |
| Start up troubleshooting. | Gost | Other Vehicles & General Automotive Discussions | 12 | 01-09-2011 06:45 PM |
| Jowett Jupiter/spark plugs | aspera | Engine, Exhaust, Transmission | 6 | 02-25-2010 06:47 PM |
