Old 02-23-2013, 01:47 PM   #1
86Sam
86Sam's Avatar
Drives: white out 86
alignment damaged my coilovers by a well known shop
I took my car in yesterday to do my alignment and they pried on the top of my camber plate and damaged it. They said this is normal for after market camber plate. Can I get some help on telling me that this is normal or not.
So first 2 pictures of the damage driver side last one was passenger.
My assumptions are that he learned that they can't pry by damaging my driver side then jacking up the car to take pressure off the camber plate to do a clean one on the passenger.
86Sam is offline   Reply With Quote
Old 02-23-2013, 02:48 PM   #2
jesperswe
Drives: GT86
lol why didnt they just put something between the prybar and top plate BEFORE trying to move it?!
jesperswe is offline   Reply With Quote
Old 02-23-2013, 02:58 PM   #3
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
No way in hell normal. I would take action.
xDBOYx is offline   Reply With Quote
Old 02-23-2013, 03:36 PM   #4
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
dam idiots
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 02-23-2013, 03:53 PM   #5
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Even if it was normal practice, is wrapping your pry bar in a shop rag or something to prevent metal-metal contact that hard?
Ravenlokk is offline   Reply With Quote
Old 02-23-2013, 04:12 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
Definitely not normal to scratch stuff up like that. Which "well known" shop did this?
Old 02-23-2013, 04:55 PM   #7
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Nothing normal about this, no tool should be required if there is no load on the hub and the slider bolts are loose.
mines13 is offline   Reply With Quote
Old 02-23-2013, 05:01 PM   #8
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Looks like ass but it should be ok very sloppy work I wouldnt have them work on my car ever again.
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 02-23-2013, 05:14 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
^^what he said. I would prime and paint the area where they removed paint from your strut tower but after that you should be fine.
I would also tell everyone I know what shop it was and I would never go back.
Edit, why aren't the strut bolts tight? Or are they tight? Any fastener should have a a bare minimum a single thread showing above the nut. That's not going to be very strong if that is tight.
Old 02-23-2013, 06:06 PM   #10
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
6 sets of coilovers on various cars..including the BRZ.. and no way thats normal.. its being lazy. they didn't unweight the corner and just used the prybar to move the camber. When , in reality, all you had to do is jack that corner up.. loosen the camber adjustment bolts and slide... no prybar no force or anything..:/ . jack it up.. slide.. adj as necessary...tighten down.... lower car. wow.. some people just don't respect peoples stuff.. :/
Scooby South is offline   Reply With Quote
Old 02-23-2013, 07:10 PM   #11
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Time to cut a bitch!!
Darryljr11 is offline   Reply With Quote
Old 02-23-2013, 07:33 PM   #12
mla163
Overthinking it
Drives: BRZ in CS
You are correct, but this is pretty standard for a camber plate. The threading on the strut is a finite length.
And, I wouldn't go back to that shop. I would let the owner know that.
mla163 is offline   Reply With Quote
Old 02-23-2013, 07:36 PM   #13
cnk
Drives: '13 DGM BRZ Limited
Agree with everything stated so far. Sounds more like it's a well known shop for cutting corners or having a lazy ass mechanic who doesn't want to do things the right way. This is one reason why if I'm forced to have someone else work on my car that I make sure I can watch them even if it means standing outside the garage in the cold due to their "insurance purposes" of not letting someone in.
cnk is offline   Reply With Quote
Old 02-23-2013, 10:45 PM   #14
Touge Monster
Most shops aren't going to spend as much time working on our cars as we would it would be impossible to turn a profit. Not to point any fingers here but I have seen some shops cut lots of corners ie cutting bending prying things that shouldn't to increase productivity this obviously was one of those cases. Why unbolt and lift when you can save yourself time on the alignment rack by prying. Sorry this happened to the op hope the shop is reputable enough to aleast comp you some new camber plates and have that tower professionally repaired.
Alignment shop in Richmond chappys4life Mid-Atlantic 3 02-06-2013 03:17 PM
Hi guys anyone know a good local shop to get tein coilovers ?? s1monn Southern California 3 01-28-2013 06:30 PM
Wind Damaged BRZ's thermobox BRZ First-Gen (2012+) — General Topics 6 08-25-2012 11:25 AM
shop in west Houston for performance wheel alignment hankster Southwest 0 08-21-2012 07:08 PM
Damaged my Bespoke unit :( Hanakuso Electronics | Audio | NAV | Infotainment 0 08-13-2012 03:10 PM
