Drives: 2013 Scion FR-S Raven
Springs & Shocks: Which to Buy?
Please forgive me if this is a repost, searched the forum, couldn't find what I was looking for.
I want to improve the looks and handling of the car and understand coilovers are optimal but seeing as how money is a little tight I decided to go with a spring and shock combo, springs now, shocks to follow in a few months. Most of my driving is weekend mountain fun and daily commute. Would like to track the car for fun sometime but definitely by no means doing it often or setting up my car to race. Not concerned with comfort. What set up do you guys recommend? Will the new set up improve the handling really or will it have a negative effect? I appreciate any advice and input. Thanks guys. |
Drives: 2013 Whiteout 6MT FR-S
You really don't need to waste your money on shocks at this point, assuming your car doesn't have too many miles. I went with Eibach Sportlines on stock shocks and couldn't be happier. Installed em by myself in about 3 hours with no power tools, only rented strut spring compressors from Napa. 1000+ miles later and not a single squeak or problem. (I personally find coils to be a waste of money unless you're 1) Stancing a car and need static or 2) tracking the car weekly.)
Thanks for the feedback! Did you have to get an alignment? How'd they effect the cars handling?
Drives: 2013 Scion FR-S MT "Panda"
OP: your name is amazing.
And can anyone chime in on a set of springs/shocks to keep the ride comfortable but with a slight drop (less than an inch) that will refine the handling a bit? I want extreme function, don't really care much for form. I'd actually like to make the car behave a little more neutrally, get rid of some of the oversteer. |
Also, is there a big difference between say H&R, Eibach, and Teins?
Drives: 2013 Raven FR-S
I highly recommend the Racecomp Engineering Yellow springs. They are matched to work with the stock struts, and they still give you a nice drop.
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Eibach is track proven for years and years.
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Get Race Comp Engineering springs if the handling is higher priority than the bigger drop (only .75 I think). Then when money allows, get Koni Sport shocks.
Eibach is a good set that most of the forum guys tend to go with. Adding springs will eventually wear our your stock shocks/struts faster than they would with stock springs of course. At that point when they wear out, I would typically add coilovers, or go with a good set of shocks.
Or if you're like me, trade them out with KW V3's with less than 2000 miles on the stockers
#10 |
False if you use springs that are matched to the stock struts. It's true if you use garbage springs that drop the car too much.
#11 | |
#12 |
Get a Bowl
Drives: 2017 BRZ PP
RCE's and yes you should get shocks. Either Konis or call Odi at Feal about having the stock ones rebuilt to match the springs.
I am not getting into a pissing match with the "experts" on here, but for longevity reasons and to save you money in the future, do it right the first time Sent from my SCH-I535 using Tapatalk 2 |
#13 | |
Get a Bowl
Drives: 2017 BRZ PP
#14 |
Do you guys recommend an alignment after installing the springs?
| TRD Springs on std shocks? | Panman | AUSTRALIA | 3 | 02-14-2013 03:59 PM |
| TRD JDM Springs on standard shocks? | Panman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-08-2013 07:49 AM |
| Forget it... I'm doing springs and shocks... not coilovers... | seven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 59 | 01-17-2013 12:31 AM |
| Coil springs on OEM shocks | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 54 | 01-04-2013 08:22 PM |
| Matching shocks with springs | Ben_G | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 07-22-2012 10:32 PM |
