Old 03-10-2013, 07:36 PM   #1
Racecomp Engineering
KDT 925 installed.
We have done many upgrades to our BRZ project car and this was one that I really looked forward to. A know on the Impreza chassis this upgrade makes a very noticeable difference. A few weeks ago we test a larger than stock driveshaft and with the car in the air we noticed a LARGE amount of rear differential movement. (by large amount I mean roughly 3/4 inch of upward movement from the front bushings and 1/2inch of rear downward movement in the stock rubber bushings).
Once on the ground and laying under the car as the clutch is engaged this is the same. So a fast shift at speed must be have a lot of movement as well.
The install took less than an hour. Instructions were simple and easy.
An initial test drive showed huge improvements when adjusting rpms mid corner( checking up). Now if you accelerate from a steady rpm you (seemingly) feel the car move forward without as much drive train flex/loss etc. Notice I said seemingly as there is no data to support this "feeling".
There is some additional NVH felt and heard now. When turning out of say a parking place at 1-3mph you do hear the differential transferring noise through the drivetrain and into the car. This was there before BUT the soft factory bushings insulate this sound. Its not loud at all, but if you listen for it with the radio off you can hear it.
At 3000 rpms there is a drivetrain rumble feeling that I can feel, but not at 2900 and not at 3100.
DISCLOSURE: I have a Cusco 4.55 final drive so this COULD be a result of THAT. None the less this isnt a big deal. On the "big deal scale" its a 2 with 10 being take it out NOW.
We also have the Whiteline trans insert installed and now with the 925 installed it "feels" like you can feel more transmission noise/grunt when shifting.
Alo keep in mind we have the subframe insert bushings installed also. So any thing that COULD keep these sounds from being heard and felt has been removed all in an effort to gain more feeling and handling potential.
DO NOT BE SCARED as what I am describing all falls under the " I want my car to handle better and are willing to incur some extra NVH to do so" category. With that said....this single mod combined with some of the other key mods gives what is other wise a very insulated car,...a very RAW feeling which.....promotes driving confidence and feeling.
Banging through the gears proves FAR more DIRECT and does seem to direct more energy to the wheels.
On some late night after the wife goes to sleep back roads I found this modification to REALLY come into its own. The transition from trail braking to power on feels like you cut out a full BLINK( or in the cinematography world, 5 frames) as now it feels very confidence inspiring to come in hot , on the brakes HARD, and as you go from brake back to gas the rear end feels more connected and or as though you are enabling the differential to perform better. I think THAT is where this part shines. SImply put there is less movement in those critical moments where you need the parts under the car and around the diff to be "ON" and ready to transition.
Whiteline offers a COMPLETE bushing replacement option coming soon and that I would imagine has MORE NVH than this so thats for sure for VERY committed track day guys/girls.
My rating on this mod is a 9.5 out of 10. I love it.
Our first track event is in a few weeks so I will give an update then.
Myles Williams
Racecomp Engineering Founder.
Old 03-10-2013, 11:47 PM   #2
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
What parts are install on this car?
Cause I can see two yellow whiteline parts :S
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-10-2013, 11:54 PM   #3
OrbitalEllipses
Drives: Attitude
Those are both part of KDT925. The ones on the side of the diff body are sometimes called "outrigger" bushings.
Old 03-11-2013, 06:06 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Nice! Thanks Myles.
oh yeah, when will these be available for general consumption?
Old 03-11-2013, 07:04 PM   #5
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Cool. I should have these coming in the next week or two so it's nice to see they do a good job. Well worth $50!
stockysnail is offline   Reply With Quote
Old 03-11-2013, 07:09 PM   #6
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I'll note that when I did the whiteline trans bushing upgrade I noticed a slight increase in NVH but within a month it became normal. I also felt like that upgrade made the car feel a bit more raw, and I would imagine this would further that feeling.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 03-11-2013, 07:21 PM   #7
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Is it similar to the amount of NVH as a 2011ish wrx with the same mods?
Ricepuddin is offline   Reply With Quote
Old 03-11-2013, 07:50 PM   #8
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Thanks Myles! Loved the writeup, and always appreciate your opinions. I really like how those rear diff bushings look like knobs, almost like a Dial-A-Diff LOL.
Thanks again Myles, can't wait for the track test.
Rick
RallySport Direct is offline   Reply With Quote
Old 03-11-2013, 11:18 PM   #9
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
can I ask why you changed the drive shaft?
jdzumwalt is offline   Reply With Quote
Old 03-11-2013, 11:32 PM   #10
I think this is key here too. I think this will break in after a while. We installed these Thursday, I came home did all the husband shit, they after the wife drank a nice barrel aged porter and fell asleep, I drifted out of the garage and did some back roads. Friday AM I was on a plane traveling. I cant wait to put some real miles on these and see if it breaks in more.
Will for sure report back.
Myles
Old 03-11-2013, 11:35 PM   #11
Rick
Thanks Rick, I try to give the drivers view on some parts. I realize some only want to see "data" but MANY things on these cars is about "feel" and how that "feeling" effects your driving and or confidence.
I will be calling you guys to get the CF driveshaft very soon. I like it because its the same size as stock and doesn't hit the tunnel or require any modifications.
[ame="http://www.youtube.com/watch?v=DsGJf21uMto"]The Albino Rhino BRZ gets a new PST Carbon Fiber Driveshaft - YouTube[/ame]
Myles
Old 03-11-2013, 11:37 PM   #12
we tested one that was larger than stock and WITHOUT these diff bushings the amount of movement caused it to touch the tunnel in 2 places. So we removed it right away.
Instead I want the PST driveshaft as its the same size as stock.
Mw
Old 03-11-2013, 11:40 PM   #13
Watch that video above and go to 1:17 and see how SMOOOTH they let the clutch out but then watch the shifts. See how much movement there is on the front diff bushings? Thats on the dyno. In real life there is ALOT of movement. I will try to set up my go pro to get some footage on a stock car and show a comparison soon.
Mw
Old 03-12-2013, 10:15 AM   #14
Calum
That Guy
Does the car in the video have the whiteline bushings? It looks like it to me.
JDM Fog Light ON and installed! 86design BRZ Photos, Videos, Wallpapers, Gallery Forum 111 09-20-2013 01:23 AM
Just Installed RS-3 Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-27-2012 10:41 AM
Does anyone have APPRADIO2 installed? Allankh Electronics | Audio | NAV | Infotainment 6 10-24-2012 09:22 PM
New ECUs being installed jpit Engine, Exhaust, Transmission 13 10-08-2012 04:00 AM
TRD Spoiler Installed JDMSushi AUSTRALIA 9 08-07-2012 01:49 PM
