Old 03-10-2013, 09:53 PM   #1
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
shock/strut replacement
hey guys.. im thinking about pairng a set of konis with the eibach pro kit. im going to try to do the work myself. for this setup, can i reuse the spring bumper, seat and upper mount?
(taken from darrendrivens diy)
sinigang_guy is offline   Reply With Quote
Old 03-16-2013, 10:35 PM   #2
SVThis
SVThis's Avatar
Drives: Scion FRS
Yes you can
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 03-16-2013, 11:14 PM   #3
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Use the bumper supplied by eibach, not your stock ones. Which koni's are u getting? I didn't know they had any apart from the inserts?
Fizz is offline   Reply With Quote
Old 03-17-2013, 01:49 AM   #4
Racecomp Engineering
We just did this install. (KONI INSERTS)Make sure you use the supplied inserts with the front strut tops during reassembly. Also make sure you drill out the rear shock top mounts as the Koni threaded shaft is larger than stock.
Myles
Old 03-17-2013, 05:00 PM   #5
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Myles
How much would you guys charge for koni+rce spring install (without alignment)?
enjoyminutemaid is offline   Reply With Quote
Old 03-17-2013, 06:31 PM   #6
fistpoint
Drives: Supercharged Golf Cart
Replacing the struts shouldn't take more than 2 hours to complete all 4 corners...but be prepared to pay 6-8 hours worth of labor that was done in 2.
Anything under 6 hours labor would be considered a "deal", which is why people often try to do this job themselves.
fistpoint is offline   Reply With Quote
Old 03-17-2013, 06:55 PM   #7
enjoyminutemaid
Thanks for the info. If anyone in the New England/Tri-state area is willing to help me with the install, I'd really appreciate it!
Old 03-19-2013, 10:15 PM   #8
sinigang_guy
the yellows. are the ones listed here inserts?
edit: yes, the items listed are inserts.
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 12:00 PM
Getting shock dynos for your shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 01-03-2013 10:26 PM
I need a stock rear shock. PLEASE help me. mrha Southern California 5 10-10-2012 10:22 PM
